hello again,
I'm am continuing my experimentation with DXF codes.
I'm want to write a lisp that will change the color and linetype of an object to color 9 and hidden2.
If the color and linetype are NOT bylayer my code works since the DXF codes for them exists. 62 = color and 6=Ltype. I basically just change what is currently there.
However if they are set to Bylayer then the DXF codes do not exist and my codes fail since I can't change what doesn't exist. I need to actually add the codes. I tried one way w/ append but it didn't work. Let me show you what I have so far.
(defun C:MakeHidden ()
 (setq ObjHid (car (entsel "\nSelect object to make hidden")))
 (setq ObjLst (entget Objhid))
 (entmod (subst (cons 62 9)(assoc 62 ObjLst) ObjLst))
 (entmod (subst (cons 6 "Hidden2")(assoc 6 ObjLst) ObjLst))
 (entupd ObjHid))
I tried this to add the codes
 (append '(62 9) ObjLst)
but that was a failure.
Here's an alternate way- it doesn't matter if the original is Bylayer
(vlax-load-com);load com
(setq obj (vlax-ename->vla-object (car (entsel))));select an entity and turn it into an object
(vlax-put-property obj 'Color 9);change the object's color to 9
(vlax-put-property obj 'Linetype "hidden2");change the object's linetype to hidden2
You're getting pretty hooked on this VL stuff... :P
I find it's much simpler for situations like this... but it can be a bear for others. I wish I knew more about the vla- functions. Vlide helps, but if you don't know what you're looking for it's kinda hard to leaf through to find a method...
True, sometimes you just have to try to put 2+2 together :geek:
yeah i'd like to learn more about the vl- functions but I don't know where to start. I just kind of pick stuff up here and there. I'm going to use the ones you mentioned. thanks alot.
There is a lot of info in the Visual LISP Help files, but most are written for VBA, so you have to make a connection.
I tried your code and I got this error at first
; error: no function definition: VLAX-LOAD-COM
I removed it and now it seems to work fine
