the-trooper Posted February 2, 2010 Posted February 2, 2010 Hello everyone I’m not sure how to explain this, so i'll use screenshots. If this is what i start with, doors as you can see: http://img3.imageshack.us/img3/2537/cad01.jpg Continue with adding balustrade: http://img141.imageshack.us/img141/1152/cad02.jpg And this is the final result that i want, without having to explode my blocks and trim everything. http://img690.imageshack.us/img690/1517/cad03.jpg Wipeout only works with closed polylines, and it is possible (draw one closed polyline all the way around), but is there any smarter, faster, better way? Thanks in advance! Quote
the-trooper Posted February 2, 2010 Author Posted February 2, 2010 But how to force that solid hatch not to plot, i.e. to "plot" white? Quote
Tiger Posted February 2, 2010 Posted February 2, 2010 But how to force that solid hatch not to plot, i.e. to "plot" white? Solid hatch is a hatch of the type SOLID, it's just a color, so to get it to plot white, you set it to the color white. And perhaps use the Send to Front command to get it in front of everything else. Quote
TimSpangler Posted February 2, 2010 Posted February 2, 2010 If you are using a vertical such as ADT ACA then there is the AECpolygon. that will do just that. Quote
NBC Posted February 2, 2010 Posted February 2, 2010 But how to force that solid hatch not to plot, i.e. to "plot" white? ensure its' colour is set to be 255,255,255 Quote
TimSpangler Posted February 2, 2010 Posted February 2, 2010 If you don't mind mitered corners you can use a region also and raise it slightly. When you plot, plot the viewport hidden and this will give you the same affect Quote
the-trooper Posted February 3, 2010 Author Posted February 3, 2010 ensure its' colour is set to be 255,255,255 This is it! Thanks boys and girls! Quote
