flopo Posted February 2, 2010 Share Posted February 2, 2010 Hello everybody, Is it possible to select inside of a polyline? Thanks! Quote Link to comment Share on other sites More sharing options...
JeepMaster Posted February 2, 2010 Share Posted February 2, 2010 Have you tried "PSELECT" then type in "WP" or any other options. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 3, 2010 Share Posted February 3, 2010 Its not worth your time Jeep, this has already been answered here Quote Link to comment Share on other sites More sharing options...
VVA Posted February 3, 2010 Share Posted February 3, 2010 My 5 cents (defun C:ICS (/ en ss lst ssall tmp head) ;;InSide Contour Select ;;!!!! [b][color="Red"]REQUIRED EXPRESS TOOLS[/color][/b] (vl-load-com) (if (and (setq en (car (entsel "\nSelect contour: "))) (wcmatch (cdr (assoc 0 (entget en))) "*POLYLINE") ) ;_ end of and (progn (setq lst (ACET-GEOM-OBJECT-POINT-LIST en 1e-3)) (setq lst (mapcar '(lambda (x) (list (car x) (cadr x))) lst)) (while lst (setq head (car lst) tmp (cons head tmp) lst (vl-remove-if '(lambda (pt) (equal pt head 1e-6)) (cdr lst) ) ;_ end of vl-remove-if ) ;_ end of setq ) ;_ end of while (setq lst (reverse tmp)) ;_ end of setq (ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list en))) (command "_.Zoom" "0.95x") (if (setq ss (ssget "_CP" lst)) (sssetfirst ss ss) ) ;_ end of if ) ;_ end of progn ) ;_ end of if ) ;_ end of defun (princ "\nType ICS") Quote Link to comment Share on other sites More sharing options...
flopo Posted February 3, 2010 Author Share Posted February 3, 2010 Nice lisp, VVA! Can you add option to select or not those objects intersecting the polyline? Those one that are/are not completely inside the poly...? Quote Link to comment Share on other sites More sharing options...
VVA Posted February 3, 2010 Share Posted February 3, 2010 Other variant (add Outside contour select ) [b][color="Red"];;;!!!! REQUIRED EXPRESS TOOLS[/color][/b] (defun C:ICS (/ en ss lst tmp head what) ;;InSide Contour Select ;;!!!! REQUIRED EXPRESS TOOLS (vl-load-com) (if (and (setq en (car (entsel "\nSelect contour: "))) [color="Blue"] (wcmatch (cdr (assoc 0 (entget en))) "*POLYLINE")[/color] (or (initget "CP WP") t) (or (setq what (getkword "\nChoose option [CrossingPolygon/WindowPolygon] <WP>:")) (setq what "WP") ) ) ;_ end of and (progn (setq lst (ACET-GEOM-OBJECT-POINT-LIST en 1e-3)) (setq lst (mapcar '(lambda (x) (list (car x) (cadr x))) lst)) (while lst (setq head (car lst) tmp (cons head tmp) lst (vl-remove-if '(lambda (pt) (equal pt head 1e-6)) (cdr lst) ) ;_ end of vl-remove-if ) ;_ end of setq ) ;_ end of while (setq lst (reverse tmp)) ;_ end of setq (ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list en))) (command "_.Zoom" "0.95x") (if (setq ss (ssget (strcat "_" what) lst)) (sssetfirst ss ss) ) ;_ end of if ) ;_ end of progn ) ;_ end of if ) ;_ end of defun (defun C:OCS ( / en ss lst ssall bbox tmp head) ;;;OutSide Contour Select ;;;!!!! REQUIRED EXPRESS TOOLS (vl-load-com) (if (and (setq en (car(entsel "\nSelect contour: "))) [color="Blue"](wcmatch (cdr(assoc 0 (entget en))) "*POLYLINE")[/color] ) (progn (setq lst (ACET-GEOM-OBJECT-POINT-LIST en 1e-3)) (setq lst (mapcar '(lambda(x)(list (car x)(cadr x))) lst)) (while lst (setq head (car lst) tmp (cons head tmp) lst (vl-remove-if '(lambda(pt)(equal pt head 1e-6))(cdr lst)) ) ) (setq lst (reverse tmp)) (if (and (setq ss (ssget "_CP" lst)) (setq ssall (ssget "_X" (list (assoc 410 (entget en))))) (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssall)))) (setq lst (vl-remove-if '(lambda(x)(minusp (cdr(assoc 62 (tblsearch "layer" (cdr(assoc 8 (entget x)))))))) lst)) (setq ssall nil ssall (ACET-LIST-TO-SS lst)) ) (progn (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (foreach e1 lst (ssdel e1 ssall)) (SSSETFIRST ssall ssall) ) ) ) ) ) (princ "\nType ICS or OCS") PS If you delete or commented out Blue line, then the contour can be also a circle, ellipse, spline Quote Link to comment Share on other sites More sharing options...
flopo Posted February 3, 2010 Author Share Posted February 3, 2010 thank you! Quote Link to comment Share on other sites More sharing options...
KoKos Posted April 13, 2015 Share Posted April 13, 2015 (edited) Other variant (add Outside contour select ) [b][color="Red"];;;!!!! REQUIRED EXPRESS TOOLS[/color][/b] (defun C:ICS (/ en ss lst tmp head what) ;;InSide Contour Select ;;!!!! REQUIRED EXPRESS TOOLS (vl-load-com) (if (and (setq en (car (entsel "\nSelect contour: "))) [color="Blue"] (wcmatch (cdr (assoc 0 (entget en))) "*POLYLINE")[/color] (or (initget "CP WP") t) (or (setq what (getkword "\nChoose option [CrossingPolygon/WindowPolygon] <WP>:")) (setq what "WP") ) ) ;_ end of and (progn (setq lst (ACET-GEOM-OBJECT-POINT-LIST en 1e-3)) (setq lst (mapcar '(lambda (x) (list (car x) (cadr x))) lst)) (while lst (setq head (car lst) tmp (cons head tmp) lst (vl-remove-if '(lambda (pt) (equal pt head 1e-6)) (cdr lst) ) ;_ end of vl-remove-if ) ;_ end of setq ) ;_ end of while (setq lst (reverse tmp)) ;_ end of setq (ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list en))) (command "_.Zoom" "0.95x") (if (setq ss (ssget (strcat "_" what) lst)) (sssetfirst ss ss) ) ;_ end of if ) ;_ end of progn ) ;_ end of if ) ;_ end of defun (defun C:OCS ( / en ss lst ssall bbox tmp head) ;;;OutSide Contour Select ;;;!!!! REQUIRED EXPRESS TOOLS (vl-load-com) (if (and (setq en (car(entsel "\nSelect contour: "))) [color="Blue"](wcmatch (cdr(assoc 0 (entget en))) "*POLYLINE")[/color] ) (progn (setq lst (ACET-GEOM-OBJECT-POINT-LIST en 1e-3)) (setq lst (mapcar '(lambda(x)(list (car x)(cadr x))) lst)) (while lst (setq head (car lst) tmp (cons head tmp) lst (vl-remove-if '(lambda(pt)(equal pt head 1e-6))(cdr lst)) ) ) (setq lst (reverse tmp)) (if (and (setq ss (ssget "_CP" lst)) (setq ssall (ssget "_X" (list (assoc 410 (entget en))))) (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssall)))) (setq lst (vl-remove-if '(lambda(x)(minusp (cdr(assoc 62 (tblsearch "layer" (cdr(assoc 8 (entget x)))))))) lst)) (setq ssall nil ssall (ACET-LIST-TO-SS lst)) ) (progn (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (foreach e1 lst (ssdel e1 ssall)) (SSSETFIRST ssall ssall) ) ) ) ) ) (princ "\nType ICS or OCS") PS If you delete or commented out Blue line, then the contour can be also a circle, ellipse, spline Sorry to resurrect this thread. I have been using this ICS command quite a bit over the last several months. Now all of a sudden it stopped working. Every time I select a polyline, it hangs for a few seconds and then gives the following: Hard error occurred *** internal stack limit reached (simulated) I am using AutoCAD 2007 and have even tried re-installing it to try to correct the issue with no luck. I also tried another computer and it has the same problem. Any help will be greatly appreciated. This has become one of my favorite commands and now I feel like I lost a finger. EDIT: So I ran it through VLINE and found which line it was breaking at. It stopped at (list en) in the line below. After commenting it out, it worked. ;; (ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list en))) Thanks, KoKos Edited April 14, 2015 by KoKos Quote Link to comment Share on other sites More sharing options...
huts Posted October 23, 2017 Share Posted October 23, 2017 Originally Posted by VVA View PostOther variant (add Outside contour select ) ... This routine is very useful. Would It be possible to add an option to select multiple objects instead of only one, as in Tharwat's routine? The linked routine is missing the OCS option, and interactive CP/WP option, which I appreciate. Quote Link to comment Share on other sites More sharing options...
