Hi,
I have attached here a dwg file which contains 2 blocks out of which one block is not visible in Layout/Viewport.
Seek quick help, Thanks in advance.
Cheers,
Ashish
Invisible Block in Layout.dwg
Hi,
Cheers,
Ashish
Its annotated at only one scale which is not the scale your viewport is set to...set viewport to show all scales & you will see it..also use PSELECT to identify annotative objects.
Add the correct scale (viewport scale)to the object & set viewport to the show current scale only & you will see it.
Also your model space is set to show objects at all scales hence why you can see it there ..
ANNOALLVISIBLE 0 = only dispaly obects that support current scale, 1 = all annotative objects will display.
Thanks a lot dear for prompt reply. You saved my tons of time.
You are a real time killer.
:D :D :D
  • 5 years later...
I just had the same problem as Ashishs. I waste few hours to find why my blocks are not visible in layout. I' so happy that I found this thread - ANNOALLVISIBLE - it is an answer for my problem. Thank you and best regards.
