caddcop Posted February 3, 2010 Posted February 3, 2010 I am trying to do some QA/QC on a file from 2008 saved back to 2004 to send to another firm. When I open the file in LD2004 and try to use the Properties command on some entities in my file, AutoCAD is telling me: C:\Program Files\Land Desktop 2004\Acopm.arx cannot find a procedure that it needs. Unknown command "PROPERTIES". Press F1 for help. How can I fix this? TIA Quote
chelsea1307 Posted February 3, 2010 Posted February 3, 2010 does this happen on all files or just the one? Quote
caddcop Posted February 3, 2010 Author Posted February 3, 2010 I just tried it in Drawing1.dwg Drew a line, right clicked on it and selected properties - same message. I recall seeing this occur in older version a long time ago but don't recall the fix. I tried swapping profiles but it was no help. Quote
chelsea1307 Posted February 3, 2010 Posted February 3, 2010 possibly need a repair, usually fixes unknown command problems Quote
Car5858 Posted February 4, 2010 Posted February 4, 2010 Turn off the registery cleaners, do a repair of the installation. This will correct the problem. The registry cleaners remove keys in the registry, that Acad uses to start up correctly. Quote
Car5858 Posted February 4, 2010 Posted February 4, 2010 Many of the anti viris, spam and spy ware programs have a section called computer maint. When you select this option; the program will allow you to select your registry to be cleaned. Make sure that box is not checked. If you are running a registry management program, the same problem can occur. All these programs are outside of the Acad files and work on your operating system. When the registry on your computer is slected for clean up, the automatic scan will remove the files for autocad from the registry. This is what I have found that causes the errors that you are having. Quote
fuccaro Posted February 4, 2010 Posted February 4, 2010 Also I experimented similar problem after installing Solid Works. In AutoCAD the Properties panel opened, but without any information in it. Quote
caddcop Posted February 9, 2010 Author Posted February 9, 2010 Thanks for everyone's help. I repaired the program and all is right with the world. Quote
orange Posted July 22, 2011 Posted July 22, 2011 Thanks for everyone's help. I repaired the program and all is right with the world. I found an easier way that worked (for me at least): go to tools->options->profiles then select RESET (you might wanna save it before reset, just in case) Quote
