I'm not a big fan ( eq )
Just look at the example of the help files:
(setq f1 '(a b c))
(setq f2 '(a b c))
(setq f3 f2)
Compare f1 and f3:
Command: (eq f1 f3)
nil
For that matter:
(eq f1 f2) returns nil
It's just not that intuitive for me.
I do use it for comparing ENAMEs in that are they are bound to symbols.
(=) converts strings to their ASCII numbers and compares them that way.
(= "Z" "z") returns nil
-David
Thanks David,
I think I've seen something like that before :)
http://www.theswamp.org/index.php?topic=29839.msg354144#msg354144
  • Replies 23
  • KRBeckman
    9
  • Lee Mac
    8
  • David Bethel
    4
  • lpseifert
    2
Another one can be strange is (/=)
(/= 1 1 2 1 1) returns nil ( at least up until 2000 )
whereas (not (= 1 1 2 1 1)) returns T
I never quite understood the reasoning:
AutoLISP Reference
Note that the behavior of /= does not quite conform to other LISP dialects. The standard behavior is to return T if no two arguments in the list have the same value. In AutoLISP, /= returns T if no successive arguments have the same value; see the examples that follow.
Examples
(/= 10 20) returns T
(/= "you" "you") returns nil
(/= 5.43 5.44) returns T
(/= 10 20 10 20 20) returns nil
(/= 10 20 10 20) returns T
Note in the last example that although there are two arguments in the list with the same value, they do not follow one another, and thus /= evaluates to T.
Interesting...
If (= 1 1 2 2) & (/= 1 1 2 2) both return nil does that mean /= compares them in pairs whereas = compares all args?
Then (not (= 1 1 2 1 1)) returns T makes sense because (= 1 1 2 1 1) is nil.
Are these results consistant with Lisp in general or just AutoLisp?
SteveK
Interesting...
as sequential pairs as I understand it:
would compare (= 10 20) then (= 20 10) then (= 10 20)
None of these return T so the /= call returns T
It's just AutoLsip as far as I know. -David
