Ydnat Posted February 8, 2010 Share Posted February 8, 2010 G'day, Can the following lisp (CookieCutter2 v1.2.lsp) be modified to select a polyline by "layername"? or is there script file (not lisp) that can select a closed polyline (or rectangle) by layername and trim/erase all entites outside it? Any help would be appreciated. I run Acad 2008 Cheers CookieCutter2_v1.0.lsp Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 8, 2010 Share Posted February 8, 2010 Shouldn't that have Joe's Name on it? ;; By Joe Burke ;; Comments and bug reports may be sent to ** email ** ;; What does CC2 do which ExpressTools extrim, AKA CookieCutter, doesn't? ;; Works with blocks, hatches and regions by exploding them. ;; Other object types which cannot be trimmed are left intact. ;; Works with objects which do not use a Continuous linetype. ;; Offers an option to delete all objects on visible layers either ;; inside or outside the selected trim object. Entire thread here: http://www.theswamp.org/index.php?topic=24646.0;all 1 Quote Link to comment Share on other sites More sharing options...
IsraelS Posted October 2, 2012 Share Posted October 2, 2012 G'day, Can the following lisp (CookieCutter2 v1.2.lsp) be modified to select a polyline by "layername"? or is there script file (not lisp) that can select a closed polyline (or rectangle) by layername and trim/erase all entites outside it? Any help would be appreciated. I run Acad 2008 Cheers ohh delivers what it promises! Quote Link to comment Share on other sites More sharing options...
sudheesh Posted November 26, 2013 Share Posted November 26, 2013 CookieCutter2_v1.0.lsp it cant be trim in 2010 pls hlp me Quote Link to comment Share on other sites More sharing options...
sudheesh Posted November 26, 2013 Share Posted November 26, 2013 i try this lisp but its not make any changes. im using cad 2010 can u pls tell me how it ill be work? Quote Link to comment Share on other sites More sharing options...
Guest Posted November 26, 2013 Share Posted November 26, 2013 use EXTRIM command Quote Link to comment Share on other sites More sharing options...
sudheesh Posted November 26, 2013 Share Posted November 26, 2013 yes i tried also EXTRIM but..... i cant trim also irregular polyline over small objects on large area ..... Quote Link to comment Share on other sites More sharing options...
