hi everybody,
I am working in autocad 2004 vba. I NEED TO CHANGE MY DRAWING NAME AT RUNTIME THRU VBA. CAN ANYONE HELP ME REGARDING THIS ISSUE
REGARDS
M.VIVEK
Did you tried the below approach?
ThisDrawing.SaveAs NewDrawingName, ac2004_dwg
Kill OldDrawingName
Regards,
hi msasu,
Thanks for your help. save as command will save the drawing in particular folder.that's correct.
without saving the drawing. i need to change the drawing name or show some names in title bar of autocad.
Regards
m.arunachalam
So, your goal is to display a custom message in AutoCAD’s title bar, not to change drawing’s name, is this correct? There is a property that store title bar’s content, but I’m afraid it is Read Only.
ThisDrawing.Application.Caption
May use instead the "MODEMACRO" system variable that will allow you to display a custom message on status bar (bottom of drawing).
ThisDrawing.SetVariable "MODEMACRO", "My info message on Status Bar"
Regards,
hi msasu,
I tried with Thisdrawing.application.caption. its not working bocz of its read only property.
now iam going to use saveas method which u had told me previously.
thank u for ur help
Regards
m.vivek
You welcome!
For sure, if you save the drawing with a new name and delete the old file, this will appear to user as a name change at run-time.
Regards,
