Transparent Hatching with Polygons and SDF Files
Im quite new to Map 3D and been trying to play around with transparent hatching over OS maps.
I've drawn a polygon.
Exported as an SDF.
Imported through the task pane.
And then when editing in style manager I set up properties to include the transparent fill and for some reason nothing happens?
I can edit the line style for the polygon but no fill appears even though I one in the preview?
Is there a checkbox somewhere I've not hit?
Thanks
  • 4 months later...
Map 3D 2011 will allow transparency of layers and entities. Until you upgrade, you may be able to use some third party add-on.
Hi Derek, it should be quite straight forward.
What are you seeing, can you see a solid fill or is the region completly transparent?
If you are sure the data polygons (and not closed polylines), check that solid fill is selected.
