Cadman2008 Posted February 11, 2010 Posted February 11, 2010 (edited) I need to draw a parabola based on this equation. y = x^2/(4*f) f = 9.846171 range of x -20.6816 to +20.66816 Now upon researching i came across a lisp routine for a parabola which is below. I'm not familiar with what this lisp is telling me. So my question is how do i go about pluging my equation in to the lisp routine to get the right parabola drawen? I'm assuming the 3rd line into the lisp routine where it give's the equation f=w^2/16/h, i would modify to say f=w^2/4*h, is this right? I would appreciate any help ; draws parabola ; to draw parabola with given width (w) and height (h) ; calculate focus-vertex distance (f): f=w^2/16/h, ; draw parabola, trim the height, verify dimensions (defun c:pbl (/ f mxx x ip y cp1 cp2 p1 p2 e1 e2 osn) (setq osn (getvar "OSMODE")) (setvar "cmdecho" 0) (if (= ff nil) (setq ff 1.0) ) (princ "\n Focus to center point of parabola <distance> < ") (princ ff) (princ " > ??: ") (initget 2) (setq f (getdist)) (if (= f nil) (setq f ff) ) (setq ff f) (if (= mxxx nil) (setq mxxx 2.0) ) (princ "\n Height < ") (princ mxxx) (princ " > ?? : ") (setq mxx (getdist)) (if (= mxx nil) (setq mxx mxxx) ) (setq mxxx mxx) (setq mx (+ mxx f)) (if (= x1 nil) (setq x1 0.1) ) (princ "\n Precision < x distance > < ") (princ x1) (princ " > ?? : ") (setq x (getdist)) (if (= x nil) (setq x x1) ) (setq x1 x) (if (> x 1) (setq x 1) ) ; -- FIRST SEGMENT --- (setq ip (getpoint "\n Insert by focus: ")) ; ip = focus point (setq y (+ f (/ (expt x 2) (* 4 f)))) ; y = distance of point from base line (setq cp1 (polar ip (* pi 1.5) (* f 2))) (setq p1 (polar cp1 (* pi 0.5) f)) (setq cp2 (polar cp1 0 x)) (setq p2 (polar cp2 (* pi 0.5) y)) (setvar "osmode" 0) (command "pline" p1 "w" 0 0 p2 "") (setq e1 (entlast)) (setq xx x) (while (> mx y) (setq xx (+ xx x)) (setq y (+ f (/ (expt xx 2) (* 4 f)))) (setq cp2 (polar cp1 0 xx)) (setq p2 (polar cp2 (* pi 0.5) y)) (command "line" "" p2 "") (setq e2 (entlast)) (command "pedit" e1 "j" e2 "" "") ) (command "mirror" e1 "" ip cp1 "") (command "circle" ip x) (setvar "osmode" osn) (princ) ) (prompt "\n type pbl for parabola") Edited August 16, 2012 by SLW210 Code Tags!! Quote
lpseifert Posted February 11, 2010 Posted February 11, 2010 This doesn't use the lisp, but here's a way... Open the attached excel file (rename it to Parabola.xls) and highlight column D Hit Ctrl+C (to copy to clipboard) In your dwg start the Pline command At the Specify start point: prompt hit Ctrl+V (to paste the data from the clipboard) Parabola.xls.txt Quote
David Bethel Posted February 11, 2010 Posted February 11, 2010 Maybe this can help. _David http://www.cadtutor.net/forum/showthread.php?t=4943&highlight=parabola Quote
SEANT Posted February 11, 2010 Posted February 11, 2010 Here's one via a degree 2 spline. Parabola.dwg Quote
BIGAL Posted February 12, 2010 Posted February 12, 2010 pretty easy as above has shown given F=9.846171 (setq 4f (* f 4.0)) y = x^2/(4*f) this is (setq y (/ (*x x ) 4f)) x= -20.6816 (setq inc (say 0.002)) (setq nums (fix (/ (* 206816 2.0) inc)))) (repeat nums (setq y (/ (*x x ) 4f)) (setq xy (list x y)) (command "point" xy) (setq x (+ x inc)) ) ; end repeat Quote
paulmcz Posted February 12, 2010 Posted February 12, 2010 Cadman, here (attached) is another one so you can do what you want. This one has 3 options for entering parameters. WH (width and height of parabola), FH (focus distance and height) and FW ( focus distance and width). Load the routine type > pbl Parabola-W+F.lsp Quote
Cadman2008 Posted February 16, 2010 Author Posted February 16, 2010 Cadman, here (attached) is another one so you can do what you want. This one has 3 options for entering parameters. WH (width and height of parabola), FH (focus distance and height) and FW ( focus distance and width). Load the routine type > pbl How accurate is this? Does it still use the equation y = x^2/(4*f) Quote
BIGAL Posted February 16, 2010 Posted February 16, 2010 Autocad uses double precision or at least single precision so should be accurate unless you work for NASA. The only thing to be carefull of is in lisp if you do x/4 this is not the same as x/4.0 the extra .0 implies to make it a real not an integer answer can make the difference sometimes. if worried about precison then rewrite in VBA etc and set all variables to double precison. Quote
paulmcz Posted February 16, 2010 Posted February 16, 2010 I wrote the original lisp and then someone requested the width, so I wrote this one. Just delete the "original" lisp and use the one I posted here. How accurate? At the third prompt, you can set the accuracy by varying "x" stepping (precision ..). Smaller the number finer the parabola. Yes, it does use the " y = x^2/(4*f) " formula.You can find it in each "while" loop in the code. Quote
