Doove Posted February 12, 2010 Posted February 12, 2010 Hi trying to install object enablers. Downloaded to c drive, ran the .exe file, a window comes up (I believe the inital window of the setup program) but it says it can't find any target applications. I also can't open the .chm help file, or rather, it does open but the right hand pane of the help window just says "Action Cancelled" - I suspect this is because we are still on IE6? Anyone know a workaround? Regards Quote
slimbone Posted February 12, 2010 Posted February 12, 2010 object enabler will only install on 32-bit software, running in a 32-bit operating system. I had this problem yesterday with one of our machines. What versions of CAD and OS are you running? Quote
Doove Posted February 15, 2010 Author Posted February 15, 2010 32 bit all the way. MEP2008 SP1 (network license) & XP. Quote
