Hi,
I'm not sure which tool do I click on in order to insert text into my drawing? Is it the MTEXT? I want to add the following a few spaces below my drawing for ex:
NAME
COURSE NAME/CLASS
SEMESTER
AutoCAD 09'
MTEXT or DTEXT will get the job done. Type either of those at the command line or use the text toolbar.
If you are using 2009 then you can find text options like Multitext or Single line text on the Ribbon. I think you have to click on the Annotation tab.
Thanks a lot Scribble and ReMark for the tips! =)
DRAW>TEXT that'll do the trick, easy enough.
Good luck taking the course.
