salmonrose Posted February 17, 2010 Posted February 17, 2010 I need to draw some pipe on a profile. The pipe is set at 0.3%. I know the starting point of the pipe, what command should I use in order to set the line to 0.3% (similar to polar tracking which you can set 15° for example). Thanks. Quote
BIGAL Posted February 18, 2010 Posted February 18, 2010 Draw a line 333.3333 units long raise 1 end 1 unit ie 1/(0.3/100) If it has a vertical scale then you need to adjust the vertical 1 units to suit the horizontal ratio. Quote
PS_Port Posted February 18, 2010 Posted February 18, 2010 I would do similar to BIGAL except, 1000 long raise 3. side note - 0.3% thats pretty flat, can they contruct/lay to that accuracy without flat spots. Quote
lpseifert Posted February 18, 2010 Posted February 18, 2010 try this ;;;draws a pline at a user designated % LPS 2009-01 (defun c:pb% (/ % oldsnang oldortho oldecho) (setq % (getreal "\nEnter percent slope: + /-: ") oldsnang (getvar "snapang") oldortho (getvar "orthomode") oldecho (getvar "cmdecho")) (setvar "cmdecho" 0) (setvar "snapang" (atan (/ % 100))) (setvar "orthomode" 1) (command "pline" pause pause "") (setvar "snapang" oldsnang) (setvar "orthomode" oldortho) (setvar "cmdecho" oldecho) (princ) ) If you're drawing at an exaggerated scale, I've got one for that too. Quote
salmonrose Posted February 18, 2010 Author Posted February 18, 2010 I would do similar to BIGAL except, 1000 long raise 3. side note - 0.3% thats pretty flat, can they contruct/lay to that accuracy without flat spots. I guess they can. The existing section is 43m long @0.4%. Mine will be 70m @0.3%, then 62m @0.4%. try this ;;;draws a pline at a user designated % LPS 2009-01 (defun c:pb% (/ % oldsnang oldortho oldecho) (setq % (getreal "\nEnter percent slope: + /-: ") oldsnang (getvar "snapang") oldortho (getvar "orthomode") oldecho (getvar "cmdecho")) (setvar "cmdecho" 0) (setvar "snapang" (atan (/ % 100))) (setvar "orthomode" 1) (command "pline" pause pause "") (setvar "snapang" oldsnang) (setvar "orthomode" oldortho) (setvar "cmdecho" oldecho) (princ) ) If you're drawing at an exaggerated scale, I've got one for that too. How do I use the above? I have never written any code before. Thanks. Quote
ScribbleJ Posted February 18, 2010 Posted February 18, 2010 Start the line where you're beginnig is then when prompted to (Specify next point or [undo]: enter the following. @100,0.003 - That is if it is actually a 0.3% slope which means it will rise or fall 0.003 feet in 100 feet. Edit: Oops had to edit my math. Quote
lpseifert Posted February 18, 2010 Posted February 18, 2010 How do I use the above? I have never written any code before. Thanks. Have a look here http://www.cadtutor.net/faq/questions/28/How+do+I+use+an+AutoLISP+routine%3F one other alternative is to add an Additional Angle in the settings of Polar Tracking 0.3%= 0.17189 degrees (atan of 0.003) Quote
