Scaling w/o pushing a command line
How would I scale a block w/o using (command "scale" etc)? thanks in advance
I'm currently trying to select multiple blocks and trying to scale each of them by the current DIMSCALE. To keep them in their place I want each one to be scaled with their insertion point as the base point. I saw a LISP by Lee Mac and tried to modify it to do my task. This is what I have but I'm getting an error.
(defun c:wscale (/ i ss ent eLst)
 (setq wgScale (getvar "DIMSCALE"))
 (if (setq i -1              ;if this = T
           ss (ssget "_:L"))
     (while            ;Then do this
       (setq ent
          (ssname ss
              (setq i (1+ i))))
     (setq eLst (entget ent))
     (setq ePT (assoc 10 eLst))
     (vl-cmdf "_.scale" ent "" ePT wgScale)
 );end if
 (princ))
I get this error
Command: WSCALE
Select objects: Specify opposite corner: 1 found
Select objects: Application ERROR: Invalid type sent as command input
it appears as thought all I was missing was a "cdr"
           ss (ssget "_:L"))
       (setq ent
          (ssname ss
              (setq i (1+ i))))
     (setq ePT [color=Red](cdr[/color] (assoc 10 eLst))[color=Red])[/color]
 );end if
 (princ))
I thought (assoc ...) would return x,y,z but it returned (10 x,y,z) which made the command line fail.
I'm going to add a 2nd part to this question. I would like to type the command and have the LISP select all the blocks in the drawing who's block name contains the word "PART".
I'm searching around for an answer in the mean time. I figure I have to filter for (0 . "INSERT") and (2 . "*part") don't think I can use an asterik there but you can see my logic.
I know this is a conversation between me, myself and I but I figure some may be reading this :lol:
anyways I noticed there are x,y and z scale factors in the DXF codes of the block. I think I'll try to change those values instead of using a command line.
I'm not sure exactly what you want to do, but can you use a quick select to get all of a block type selected, then modify the properties x,y,z scales?
Glen
Example:
(defun c:wscale  (/ i ss ent eLst scl)
 (and (zerop (setq scl (getvar "DIMSCALE")))
      (setq scl 1.0))
 (if (setq i  -1 ss (ssget "_:L" '((0 . "INSERT"))))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (mapcar
       (function
         (lambda (x)
           (setq eLst (subst (cons x scl)
                             (assoc x eLst) eLst)))) '(41 42 43))
     (entmod eLst)))
 (princ))
