knaabis Posted February 19, 2010 Posted February 19, 2010 I want to convert a .dwg file into .3ds file. Is it possible? Quote
fuccaro Posted February 19, 2010 Posted February 19, 2010 Welcome in the forum, Knaabis! See here: http://www.cadtutor.net/forum/showthread.php?t=18243 Give a try to the search function of the forum (in the top of the page, bellow the adverts there is a button called Search). You will find more links, this subject was discussed a couple of times. Quote
Cad64 Posted February 20, 2010 Posted February 20, 2010 Why do you want to convert your CAD file to .3ds? If you want to take it into Studio Max, you can Import your .dwg file directly. In fact, many programs can Import .dwg or .dxf files these days. Check the Import options of the program you want to bring your CAD file into. Quote
