Elektryk Posted February 21, 2010 Author Posted February 21, 2010 ok it does work but ... whatever object i select it draws the same half circle that i have here in the template Quote
paulmcz Posted February 21, 2010 Posted February 21, 2010 ok it does work but ... whatever object i select it draws the same half circle that i have here in the template Yes, I know. Quote
Elektryk Posted February 21, 2010 Author Posted February 21, 2010 the lisp has to somehow copy the object that im selecting and offset it 1/8 (in or out ) and draw a border around it with 2" clearance on each side and 9" high the little circles on top corners are not needed Quote
Lee Mac Posted February 21, 2010 Posted February 21, 2010 These should get you started: http://www.afralisp.net/ http://www.jefferypsanders.com/autolisptut.html http://ronleigh.info/autolisp/index.htm Quote
BearDyugin Posted February 23, 2010 Posted February 23, 2010 Look on YouTube how this Lisp works frto.LSP Quote
Elektryk Posted February 23, 2010 Author Posted February 23, 2010 it still does the same thing pretty much copies it ...... again.... u got 20 half circles 20 squares 20 different shapes and u need a form around it with a 1/8 offset.... i dont know how else to explain that.... oh yea and they are all different sizes.... Quote
Lee Mac Posted February 23, 2010 Posted February 23, 2010 dont understadn any of it It doesn't just sink in straight away - you need to spend some time with it, and actually give it a go. Quote
alanjt Posted February 23, 2010 Posted February 23, 2010 It doesn't just sink in straight away - you need to spend some time with it, and actually give it a go. Lee, you forget. This is the microwave generation. If it isn't instantaneous, it's obviously broken or impossible! Quote
Lee Mac Posted February 23, 2010 Posted February 23, 2010 Lee, you forget. This is the microwave generation. If it isn't instantaneous, it's obviously broken or impossible! I must've been born into the wrong generation Alan... Quote
alanjt Posted February 23, 2010 Posted February 23, 2010 I must've been born into the wrong generation Alan... I know I was. Quote
Elektryk Posted February 24, 2010 Author Posted February 24, 2010 I know I was. ok..... back to the topic... Quote
