Kelly Posted February 19, 2010 Posted February 19, 2010 When Attempting to laud Autodesk Design Review 2010 error message either directly or via autocad 2010 0xc0000142. appears. with a full install why would this not work? Quote
Kelly Posted February 19, 2010 Author Posted February 19, 2010 i found this: Solution This error occurs because AutoCAD® and 3ds Max® share some components. As a result, removing one of these Autodesk applications can affect the other one. To resolve this issue, download and run the appropriate fix for your bundle: For AutoCAD Revit Architecture Visualization Suite, download and run 3dsMaxRAV-S_Anchor.msi. For the AutoCAD Visualization Suite, download and run 3dsMaxACDDS_Anchor.msi. After you have applied this fix, you will be able to start and use 3ds Max normally. Quote
