OLE cannot be selected
Hi,
I am using AutoCAD 2004. I have an OLE object I think (it is a company logo) and I cannot select it to delete it. Any idea?
How to do that? I typed OLEFRAME at the command line but did not recognize it.
Try typing OLE into the command line, and instead of pressing return to execute
the command, press tab to cycle through the various ole commands, which ones
do you get?
(may be a case that OLEFRAME command was in a later release than 2006)
OLE is not a recognized command. Anyway, I tried all the avalaible OLE commands and it did not work.
Hmmm, i'll have a dig around some of my old reference books an see if can find
anything (may be a while they're all at home), i'll let you know if i do or don't. :)
I checked on the imageframes, if it is an OLE that wont affect it, however if it is an image you may have the fames turned off.
Also is it on a locked layer?
