Hey everyone, I'm having a problem with text masking in Xrefs. We ususally do our text in paperspace and we subconsulting on a project that wants text in modelspace in the xref.
The problem is: When I mask the text in the [Electrical] Xref, it masks out the other drawings that are overlayed into that Xref, but when I go to my drawing and Overlay the [Elecrical and Other] Xrefs the text mask doesnt mask the [Other] Xrefs, although it will mask the items in the [Electrical] Xref.
I know I can Xclip, but is that the only way to remedy the problem? I cannot wipeout becasue it will wipe my text!
Any help will be greatly appreciated! I will attach a screenie in a min.
Quick question - in the properties whats the definde text width and/or height?
Width is [9/32"] and Height is [0"], maybe this is the problem?? ill mess with the numbers...
Well, I tried adjusting the height to the correct value but to no avail...
Try setting them both to 0 and see how that goes. That's usually the
solution, Also once you've put the text where you want it make sure
that it's at the front in draw order
Both set at 0 and brought to the front, still no beans. I should also mention this is Mtext.
have you tried auditing the drawing in case there's something worng that audit can fix?
Sorry for the delay, had a meeting, but Auditing did not help the problem.
Fixed it. What I had to do was:
In my Xref
1. Send the other Xrefs to the back.
2. Save
In the Drawing
1. In model space send all other Xrefs to the back and Bring mine to the front
2. THEN In layout view I had to go through the viewport and do the same (send all other Xrefs to the back, then bring mine to the front)
Now it seems to work fine, must be a glitch somewhere, but thanks for the help!
No probs, seems mad that had to do it in xrefs as well :)
