Annotative hatches not showing up
I made some annotative hatches which show up fine, but then I tried xref'ing that file and for some reason the hatches don't show up, even if I have the "show annotative objects for all scales" option enabled. Anyone know what's going on?
1 - make sure your current drawing is set to display annotative objects (symbol with lightbulb @ bottom right).
2 - Maybe the drawing you're trying to XREF into is changing the annotative scale of the hatches to something other than intended, causing the hatch to not even be viewable (because the scale is just way too big).
3 - Ensure the hatch layer(s) are not frozen or turned off in the XREF itself, as well as the original drawing you're XREF'ing.
Unfortunately, these kinds of problems are one big reason I stay away from annotative objects entirely. I am hardly an expert.
-ChriS
