Hi everybody, I have just joind this website and a complete beginner and need help.
My problem is that when I type in text in model space and as soon as I finish and tap in entre twice the text disapears. Please help, I am using CAd 2010.
Thanks in advance
  • Replies 26
  • Bighitter
    12
  • skipsophrenic
    6
  • BearDyugin
    3
  • Dana W
    2
Posted Images
Is the layer you are working on frozen/turned off?
I am afraid my knowledge of CAD is not that good, therefore, would not know how and where to look for whther the layer is frozen or turned off. Any guidance would be much appreciated.
Thanks for coming back, yes I have checked the layers and they are all the same, they are not frozen or turned off.
Just had an odd thought, is the text annotative?
I clicked on Annotation on the ribbon and then single line and then tried to enter the text.
I not thinkin too good at mo (Really tired) but go into the help and read up on Annotative Scaling, see if that helps - if not I'll try help out a bit more after I've got some sleep.
I do appreciate your help. I will try read up in help and see if I can find the solutuion.
Bighitter did you find out what the problem was?
Hi Skipsophrenic
Thanks for asking but no I did not.
Although everything is working fine in a new drawing. Its a mystery, I must have turned something off or something?
Righto, sorry i couldn't be more of a help mate
I will assume such variant
Dude, how did you make that video clip? That's awesome!
Dear Muddbutter, thanks for a great video, can I have the sound please and if possible is it in English. Thanks, You have solve my problem. This is exactly what was happening.
Is it really difficult to make inquiry in google "screen recorder"?
I'm having this same problem that is on the movie clip, how do I correct this?
It would be great if soembody can translate and add voice to the above clip, hopefully then we will understand why the text is disappearing!!!
I will try to translate that has occurred on my clip
At creation of a new file with a template by default as 1 unit of the drawing 1 mm is accepted. Therefore and the plotting area is established an order of 10 metres, i.e. 10000 mm accordingly 10000 units of the drawing, and ours (mine it is exact) the text has height 2, i.e. in 10000 times it is less, therefore we it and do not see. In this cases zoom all (double cliques skroll mouse) will rescue us.
But if at creation of a new file we choose a metric template for 1 unit of the drawing the metre will be accepted, and the area of plotting of an order of 10 metres will correspond to 10 units of the drawing, and ours text in height 2, even will be very largely written.
Thanks Geobuilder, I will try and let you know what happens!!
