David Bethel Posted February 22, 2010 Posted February 22, 2010 I'm currently using Bink to compile and compress my images into a movie ( .exe ) http://www.radgametools.com I've tried Paintshop Pro Animation and various slide show makers without a lot of luck. Bink does fairly good but the frame to frame transition can leave a bit to be desired. ( it is focussed more for gaming software ) Anyone have any software suggestions: 30-33 frames per second 1024 x 768 frames ( TGA BMP or JPG ) 1,000 to 3,000 frames File size compression is not an issue Looking for best quality video TIA -David Quote
Car5858 Posted February 22, 2010 Posted February 22, 2010 I use Cyberlink power director, at least the transitions duration and type can be modified easily. Quote
David Bethel Posted February 22, 2010 Author Posted February 22, 2010 Thanks, I'll take a look It gets reviews all over the board..... http://download.cnet.com/CyberLink-PowerDirector/3640-13631_4-10483012.html?tag=uo;uo -David Quote
Car5858 Posted February 23, 2010 Posted February 23, 2010 I had to save the project I was working on after each change to prevent crashing repeatedly. Once I up graded the ram on my workstation, I have not had a problem with crashing. Quote
