how to use multiline text in aligned dimension
When I want to change the text in Aligned dimension, I go to "text override", but i don't know how to make the text multi line if the text is long.
Thanks for help.
To get a paragraph break type \P. To get text below the dimension line type \X. Note upper case letters.
And also look up in Help:- "Dimension text, user text"
Also, right before you position the dimension, type M for "MTEXT". This will allow you to make your edit on the fly instead of having to resort to the Properties box.
