Delete everything on a layer (including what's inside a block)
Yeah, but it would have just been wierd to let that go on too long.
Oh I know, baby.:wink:
  • 3 months later...
  • Replies 26
  • Lee Mac
    8
  • alanjt
    7
  • KRBeckman
    6
  • ksperopoulos
    2
Perhaps:
(defun c:DeleteAll (/ *error* LAYER UFLAG)
 (vl-load-com)
 ;; Lee Mac  ~  23.02.10
 (defun *error* (msg)
   (and UFlag (vla-EndUndoMark *doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (setq layer "Blah")
 (setq *doc (cond (*doc) ((vla-get-ActiveDocument
                            (vlax-get-acad-object)))))
 (if (and (tblsearch "LAYER" layer)
          (eq :vlax-false
              (vla-get-lock
                (vla-item (vla-get-Layers *doc) layer))))
     (setq uFlag (not (vla-StartUndoMark *doc)))
     (vlax-for lay (vla-get-Layouts *doc)
       (vlax-for obj (vla-get-Block lay)
         (if (eq (strcase layer)
                 (strcase (vla-get-layer obj)))
           (vl-catch-all-apply
             (function vla-delete) (list obj)))))
     (vlax-for blk (vla-get-Blocks *doc)
       (vlax-for obj blk
           (vl-catch-all-apply
     (setq uFlag (vla-EndUndomark *doc)))
   (princ "\n** Layer Locked or Not Found **"))
 (princ))
Is there any way to get this to select all non-plotting layers even if they are frozen, off, locked, in a block, or in an attribute?
VVA - This didn't delete the objects on the non plotting layers. This is a lot of code. Not knowing how to manipulate something this large, is there something in particular I need to change to get it to delete the non plotting layers?
BGLAYDEL - delete frozen and off layers with objects
There are 2 ways -
1. off non plotting layers
2. Found string vla-get-freeze. You will find this part of the code:
(if (or (= (vla-get-freeze item) :vlax-true)
    (= (vla-get-layeron item) :vlax-false)
) ;_ end of or
Add one more string
[b][color="Red"]    (= (vla-get-Plottable item) :vlax-false)[/color][/b]
) ;_ end of or
  • 7 years later...
WCMATCH
(defun c:deleteall (/ *error* layer uflag)
 (vl-load-com)
 ;; RJP - 06.30.2017
   (and uflag (vla-endundomark *doc))
   (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **")))
 ;; Separate layer names with commas for WCMATCH below ( removed check if layers are locked so it's up to you  )
 (setq layer (strcase "Layer1,Layer2,Layer3"))
	   ((vla-get-activedocument (vlax-get-acad-object)))
 (setq uflag (not (vla-startundomark *doc)))
 (vlax-for lay	(vla-get-layouts *doc)
   (vlax-for obj (vla-get-block lay)
     (if (wcmatch (strcase (vla-get-layer obj)) layer)
(vl-catch-all-apply (function vla-delete) (list obj))
 (vlax-for blk	(vla-get-blocks *doc)
   (vlax-for obj blk
 (setq uflag (vla-endundomark *doc))
  • 2 years later...
On 6/29/2017 at 11:22 AM, ronjonp said:
WCMATCH
 (vl-load-com)
 ;; RJP - 06.30.2017
   (vlax-for obj blk
Thank you very much.  I have been searching for a lsp to do exactly this for a week!
