rkent Posted February 25, 2010 Share Posted February 25, 2010 It seems to work at any time. [ATTACH]17659[/ATTACH] You are correct, I swear this didn't work in previous releases. Nice to know but I will stay with the UCS method with Ortho on. Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 25, 2010 Share Posted February 25, 2010 You are correct, I swear this didn't work in previous releases. Nice to know but I will stay with the UCS method with Ortho on. And I'm not abandoning my Per routine. I think I might start using Polar Tracking, though. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 25, 2010 Share Posted February 25, 2010 You are correct, I swear this didn't work in previous releases. After you mentioned it, I was thinking the same thing too, until I tried it. I don't have 2004/5/6 (or whenever Polar trk was added) to try though... Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted October 14, 2012 Share Posted October 14, 2012 I wrote this for accomplishing that very thing. Mine will allow you to the closest point (based on your selection), closest end point or picked point.http://www.cadtutor.net/forum/showpost.php?p=305119&postcount=53 You'll need a few subroutines (stated in the info), you can find them here.. http://www.cadtutor.net/forum/showthread.php?t=40344 Alan, can you please, post it again? This links looks like not available. Thank you. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 15, 2012 Share Posted October 15, 2012 I think I might start using Polar Tracking, though. Once I discovered Polar and Object Snap Tracking, I use Ortho only on rare occasions. Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 15, 2012 Share Posted October 15, 2012 Alan, can you please, post it again? This links looks like not available.Thank you. (defun c:PER (/ e p) ;; Draw Perpendicular Line, based on selected *line segment ;; Required Subroutines: AT:GetSel, AT:Segment, AT:ClosestPoint, AT:DrawX ;; Alan J. Thompson, 11.10.09 / 02.08.11 (redraw) (if (and (setq e (AT:GetSel entsel "\nSelect object for angle: " (lambda (x) (wcmatch (cdr (assoc 0 (entget (car x)))) "AECC_ALIGNMENT,AECC_PARCEL_SEGMENT,LINE,*POLYLINE" ) ) ) ) (progn (if (wcmatch (cdr (assoc 0 (entget (car e)))) "AECC*") (initget 0 "Selection") (initget 0 "End Selection") ) (setq pt (cond ((getpoint (if (wcmatch (cdr (assoc 0 (entget (car e)))) "AECC*") "\nSpecity starting point [<Selection>]: " "\nSpecify starting point [End/<Selection>: " ) ) ) ("Selection") ) ) ) ) ((lambda (point) (vl-cmdf "_.line" "_non" point (strcat "<" (angtos (+ (/ pi 2.) (apply 'angle (mapcar '(lambda (x) (trans x 0 1)) (cadr (AT:Segment e)))) ) (getvar 'AUNITS) 4 ) ) PAUSE ) (redraw) ) (AT:DrawX (cond ((vl-consp pt) pt) ((eq pt "Selection") (trans (vlax-curve-GetClosestPointTo (car e) (trans (cadr e) 1 0)) 0 1) ) ((eq pt "End") (trans (AT:ClosestPoint e) 0 1)) ) 1 ) ) ) (princ) ) (defun AT:GetSel (meth msg fnc / ent) ;; meth - selection method (entsel, nentsel, nentselp) ;; msg - message to display (nil for default) ;; fnc - optional function to apply to selected object ;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC"))) ;; Alan J. Thompson, 05.25.10 (while (progn (setvar 'ERRNO 0) (setq ent (meth (cond (msg) ("\nSelect object: ") ) ) ) (cond ((eq (getvar 'ERRNO) 7) (princ "\nMissed, try again.")) ((eq (type (car ent)) 'ENAME) (if (and fnc (not (fnc ent))) (princ "\nInvalid object!") ) ) ) ) ) ent ) (defun AT:Segment (entPnt) ;; Retreive segment number and Start & End points ;; entPnt - List with entity (ENAME or VLA-OBJECT) & point ;; Alan J. Thompson, 11.10.09 / 08.19.10 / 11.15.11 (if (vl-consp entPnt) ((lambda (e p / n) (if (setq n (vlax-curve-getPointAtParam e (1+ p))) (list p (list (vlax-curve-getPointAtParam e p) n)) (list p (list (vlax-curve-getPointAtParam e (1- p)) (vlax-curve-getPointAtParam e p))) ) ) (car entPnt) (fix (vlax-curve-getParamAtPoint (car entPnt) (vlax-curve-getClosestPointToProjection (car entPnt) (trans (cadr entPnt) 1 (car entPnt)) '(0. 0. 1.) ) ) ) ) ) ) (defun AT:ClosestPoint (ep / _next _dist ep el lst) ;; Return closest point to selected entity ;; ep - entity and point list ;; Alan J. Thompson, 09.14.10 (defun _next (e / p) (if (and (setq e (entnext e)) (setq p (cdr (assoc 10 (entget e))))) (cons p (_next e)) ) ) (defun _dist (a b) (distance (list (car a) (cadr a)) (list (car b) (cadr b)))) (if (and (vl-consp ep) (eq (type (car ep)) 'ENAME) (or (eq 1 (getvar 'worlducs)) (setq ep (list (car ep) (trans (cadr ep) 1 0)))) (cond ((vl-position (cdr (assoc 0 (setq el (entget (car ep))))) '("ARC" "LINE" "SPLINE")) (setq lst (list (vlax-curve-getStartPoint (car ep)) (vlax-curve-getEndPoint (car ep)))) ) ((eq (cdr (assoc 0 el)) "LWPOLYLINE") (foreach p el (and (eq (car p) 10) (setq lst (cons (cdr p) lst)))) lst ) ((eq (cdr (assoc 0 el)) "POLYLINE") (setq lst (_next (car ep)))) ) ) (car (vl-sort lst (function (lambda (a b) (< (_dist a (cadr ep)) (_dist b (cadr ep))))))) ) ) (defun AT:DrawX (P C) ;; Draw and "X" vector at specified point ;; P - Placement point for "X" ;; C - Color of "X" (must be integer b/w 1 & 255) ;; Alan J. Thompson, 10.31.09 (if (vl-consp P) ((lambda (d) (grvecs (cons C (mapcar (function (lambda (n) (polar P (* n pi) d))) '(0.25 1.25 0.75 1.75) ) ) ) P ) (* (getvar 'VIEWSIZE) 0.02) ) ) ) Once I discovered Polar and Object Snap Tracking, I use Ortho only on rare occasions. Same. Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted October 15, 2012 Share Posted October 15, 2012 Thank you very much. Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 15, 2012 Share Posted October 15, 2012 Thank you very much. No problem. Enjoy, but don't ignore Polar and OTracking. Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted October 15, 2012 Share Posted October 15, 2012 no problem. Enjoy, but don't ignore polar and otracking. Yes sir! I will! Quote Link to comment Share on other sites More sharing options...
