Hello:
How to connect to AutoCAD on Windows7 (or Vista) 64-bit from standing alone VB6 application?
Why the following code (or similar simple procedures, like ACADDOC.SendCommand...) is producing “Type mismatch” error in above-shown environment.
''sample of code....
Public ACADAPP As AcadApplication
Public ACADDOC As AcadDocument
Private Sub GetLength()
Set ACADAPP = GetObject(, "Autocad.Application")
Set ACADDOC = ACADAPP.ActiveDocument
AppActivate ACADAPP.Caption
MsgBox (ACADDOC.Utility.GetDistance(, vbCrLf & "Get Length:"))
End Sub
What is the name of reference and location of AutoCAD VBA library on 64-bit OS?
For AutoCAD2010 on Windows XP 32-bit those are:
AutoCAD 2010 Type Library (IS IT DIFFERENT IN 64-BIT?)
C:\Program Files\Common Files\Autodesk Shared\acadx18enu.tlb (IS IT DIFFERENT IN 64-BIT?)
Any help will be appreciated
Alex
First, presume that you have already installed VBA Enabler for AutoCAD 2010 since isn’t natively supported on this version.
Second, I think that using GetObject statement is required to specify AutoCAD version also:
Set ACADAPP = GetObject(, "Autocad.Application[color=red].18[/color]")
Or use CreateObject statement to launch default installation or your workstation:
Set ACADAPP = CreateObject(, "Autocad.Application")
Regards,
PS. Try to use code formatter (# button) to improve readability of your post.
Unfortunately, adding .18 doesn't help
Set ACADAPP = GetObject(, "Autocad.Application.18") doesn't work.
Alex
