Changing decimal places on dimensions
Thanks for having me on the site. I am an old AutoCad13 expert 1300 hrs before letting go in 1994. I am now getting back into it a little bit. I am using AutoCad lt 2010.
I would like to get my decimals place, arrow type/size set as a default. How do I do that. I tried on my own did a google search and still cant get it.
thanks in advance.
WOW! It must be the sleep I got last night! I finally found what I was looking for. For anybody else that has this problem, there is a tiny down to the right point arrow on the Annotate Dimension menu bar. Once you select that it is pretty straight forward on how to set and name your own style.
You can also access that through Format> textstyle.
If you want the menu bar at the top of the window type > menubar
(in the command line)> change the value to 1, This will enable you to
find many different options and menus quickly.
