Small Fish Posted February 26, 2010 Posted February 26, 2010 In a dwg file that has more than one tab I would like to check if the plotter device is set to 'NONE' on any of the tabs. First I tried using : (setq GetActivePlotDevice(vla-get-ConfigName (vla-get-ActiveLayout (vla-get-activedocument (vlax-get-acad-object))))) to find the plotter device in the current tab. This doesn't seem to work. Is there a way to find the plotter device name? I other questions but that is all for now - thanks cheers Quote
Lee Mac Posted February 26, 2010 Posted February 26, 2010 Perhaps something like this? (defun GetPlotDevices (/ dvc) (vl-load-com) ;; Lee Mac ~ 26.02.10 (vlax-map-collection (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (function (lambda (layout) (vla-RefreshPlotDeviceInfo layout) (setq dvc (cons (cons (vla-get-name layout) (vla-get-ConfigName layout)) dvc))))) (reverse dvc)) Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 (vla-get-configname (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) Works just fine for me. Returns "None" if nothing or the plotting device name. Edit: Oops, didn't realize you replied. I hit reply, got up for a second, sat back down and finished responding. Quote
Lee Mac Posted February 26, 2010 Posted February 26, 2010 Edit: Oops, didn't realize you replied. I hit reply, got up for a second, sat back down and finished responding. Hey, no worries dude As you say, the code that SmallFish posted seemed to be correct, but sometimes I find you have to call: (vla-RefreshPlotDeviceInfo <layout>) first. Lee Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 Hey, no worries dude As you say, the code that SmallFish posted seemed to be correct, but sometimes I find you have to call: (vla-RefreshPlotDeviceInfo <layout>) first. Lee That's true. I've encountered that in the past. Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 I was just curious... (defun PlotDevices (/ #List) (vlax-for x (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) (vla-refreshplotdeviceinfo x) (setq #List (cons (cons (vla-get-name x) (vla-get-configname x)) #List)) ) ;_ vlax-for (reverse #List) ) ;_ defun Command: (benchmark '( (getplotdevices) (plotdevices) )) Elapsed milliseconds / relative speed for 64 iteration(s): (PLOTDEVICES)........1203 / 1.17 <fastest> (GETPLOTDEVICES).....1407 / 1.00 <slowest> Command: (benchmark '( (getplotdevices) (plotdevices) )) Elapsed milliseconds / relative speed for 64 iteration(s): (GETPLOTDEVICES).....1218 / 1.00 <fastest> (PLOTDEVICES)........1219 / 1.00 <slowest> Command: (benchmark '( (getplotdevices) (plotdevices) )) Elapsed milliseconds / relative speed for 64 iteration(s): (PLOTDEVICES)........1219 / 1.01 <fastest> (GETPLOTDEVICES).....1234 / 1.00 <slowest> Command: (benchmark '( (getplotdevices) (plotdevices) )) Elapsed milliseconds / relative speed for 64 iteration(s): (GETPLOTDEVICES).....1219 / 1.00 <fastest> (PLOTDEVICES)........1219 / 1.00 <slowest> Command: (benchmark '( (getplotdevices) (plotdevices) )) Elapsed milliseconds / relative speed for 64 iteration(s): (PLOTDEVICES)........1218 / 1.00 <fastest> (GETPLOTDEVICES).....1219 / 1.00 <slowest> Quote
Small Fish Posted February 26, 2010 Author Posted February 26, 2010 Thanks Alan and Lee mac .....so it was the old "vla-RefreshPlotDeviceInfo" function that I needed . cheers . Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 Thanks Alan and Lee mac .....so it was the old "vla-RefreshPlotDeviceInfo" function that I needed . cheers . Enjoy and have a good weekend. Quote
Small Fish Posted February 26, 2010 Author Posted February 26, 2010 One more question... I would like to alert/princ the user that there are one or more tabs that have 'none' as the plot device - how do I check for any 'none' pairs in the dvc dotted pair list? thanks Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 One more question...I would like to alert/princ the user that there are one or more tabs that have 'none' as the plot device - how do I check for any 'none' pairs in the dvc dotted pair list? thanks Maybe something like this... (and (setq #Alert "") (foreach x (GetPlotDevices) (and (eq "None" (cdr x)) (setq #Alert (strcat #Alert (car x) "\n")) ) ;_ and ) ;_ foreach (alert (strcat "Layouts without defined plotter devices:\n\n" #Alert)) ) ;_ and Quote
Small Fish Posted February 26, 2010 Author Posted February 26, 2010 Hey Alan that looks good (I can't try it yet - but I'm sure it works) many thanks SM Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 Hey Alan that looks good (I can't try it yet - but I'm sure it works) many thanks SM I think it'll give you what you need. Quote
Lee Mac Posted February 26, 2010 Posted February 26, 2010 Thanks Alan, I realised that vlax-map-collection is slower, but I fancied a change They should make vlax-map-collection act like mapcar to make it really useful. Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 Thanks Alan, I realised that vlax-map-collection is slower, but I fancied a change They should make vlax-map-collection act like mapcar to make it really useful. I'd never used vlax-map-collection. I was just curious about the speed. Quote
Small Fish Posted March 1, 2010 Author Posted March 1, 2010 Alan thanks yes it works well and I like that alert box that can add depending on the list. However I seem to be having a problem with the alert box not working intermittely - and I'm not sure why? I originally also was going to make a list of tabs that had the printer set to 'NONE' however that may be too difficult. What I was trying to do is exit the code if any of the tabs selected are set to 'None' then asking the user to set to a printer device. now I've got sore eyes and a headache... I'm trying to: 1) I want to make the alert box work again 2) exit if 'none' is selected for a plotter device 3) If tabs selected do not have any 'none' then continue on. (maybe even let the user change the plotter device while program is running - but that sounds difficult) (defun c:plotdev2 (/ layout dvc #Alert layouts_to_plot) (vl-load-com) (vlax-map-collection (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (function (lambda (layout) (vla-RefreshPlotDeviceInfo layout) (setq dvc (cons (cons (vla-get-name layout) (vla-get-ConfigName layout)) dvc))))) (reverse dvc) (and (setq #Alert "") (foreach x dvc (and (eq "None" (cdr x)) (setq #Alert (strcat #Alert (car x) "\n")) ) ;_ and ) ;_ foreach (alert (strcat "Layouts without defined plotter devices:\n\n" #Alert)) (exit) ) ;_ and (setq layouts_to_plot (dos_multilist " A3 prints to printer" "Select drawings to be printed" (ListLayouts))) ;more to be added later.... (princ) );defun Quote
Lee Mac Posted March 1, 2010 Posted March 1, 2010 Something like this perhaps: (defun c:plotdev2 (/ GetPlotDevices lst2str Devices) (vl-load-com) (defun GetPlotDevices (/ dvc) ;; Lee Mac ~ 26.02.10 (vlax-map-collection (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (function (lambda (layout) (vla-RefreshPlotDeviceInfo layout) (setq dvc (cons (cons (vla-get-name layout) (vla-get-ConfigName layout)) dvc))))) (reverse dvc)) (defun lst2str (lst del) (if (cdr lst) (strcat (car lst) del (lst2str (cdr lst) del)) (car lst))) (if (setq Devices (vl-remove-if-not (function (lambda (x) (eq "None" (cdr x)))) (GetPlotDevices))) (alert (strcat "Layouts without defined plotter devices:\n\n" (lst2str (mapcar (function car) Devices) "\n")))) (princ)) Quote
alanjt Posted March 1, 2010 Posted March 1, 2010 ?? (defun test (/ #Msg) (setq #Msg "") (vlax-for x (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) (vla-refreshplotdeviceinfo x) (and (eq (vla-get-configname x) "None") (setq #Msg (strcat #Msg (vla-get-name x) "\n")) ) ;_ and ) ;_ vlax-for (if (eq "" #Msg) (alert "All layouts have a defined plotter device.") (alert (strcat "Layouts without defined plotter devices:\n\n" #Msg)) ) ;_ if ) ;_ defun Quote
Small Fish Posted March 1, 2010 Author Posted March 1, 2010 wow! that works well - thanks Alan and Lee8) there's so much to learn..... Quote
Lee Mac Posted March 1, 2010 Posted March 1, 2010 You're welcome Mr Fish - I probably went for the more OOP approach, but Alans will most likely be faster. Quote
alanjt Posted March 1, 2010 Posted March 1, 2010 wow! that works well - thanks Alan and Lee8)there's so much to learn..... You're welcome. There's always something new to learn. You're welcome Mr Fish - I probably went for the more OOP approach, but Alans will most likely be faster. Well, I just thought I'd show him a less laborious option. Nothing wrong with yours, it's just slowed down by processing the same list 3 times, plus the recursion sub. What's the OOP approach? Quote
