AcadBlockReference VBA InsertionPoint Edit
I want to edit the insertion point of multiple block references. I've been trying to edit them using this code:
Private Sub FINDMARQBOOKINLAYOUTS()
Dim OBJLAYOUT As AcadLayout
Dim AOBJ As AcadEntity
Dim MARK As AcadBlockReference
Dim INSSTR As String
Dim ATTDATE As String
Dim LAYOUTNAME As String
Dim INSPOINT(0 To 2) As Variant
ThisDrawing.SetVariable "REGENMODE", 0
INSPOINT(0) = -0.125
INSPOINT(1) = -0.125
INSPOINT(2) = 0
For Each OBJLAYOUT In ThisDrawing.Layouts
   If OBJLAYOUT.Name = "Model" Then
   Else
   ThisDrawing.ActiveLayout = OBJLAYOUT
   LAYOUTNAME = OBJLAYOUT.Name
       'COUNT1 = COUNT1 + 1 ' THIS IS JUST FOR VERIFICATION
       'START BLOCK ITERATION
       For Each AOBJ In ThisDrawing.ActiveLayout.Block
           If TypeOf AOBJ Is AcadBlockReference Then
               If AOBJ.Name = "MARQ-BOOK" Then
                   Set MARK = AOBJ
                   MARK.InsertionPoint(0) = INSPOINT(0)
                   MARK.InsertionPoint(1) = INSPOINT(1)
                   MARK.InsertionPoint(2) = INSPOINT(2)
                   INSSTR = INSSTR & "(" & MARK.InsertionPoint(1) & "," & MARK.InsertionPoint(1) & "," & MARK.InsertionPoint(2) & ")"
               End If
           End If
       Next AOBJ
   End If
Next OBJLAYOUT
ThisDrawing.SetVariable "REGENMODE", 1
MsgBox INSSTR
Unload Me
End Sub
This macro iterates the Layouts, finds an specific block reference and then my attempt is to change its insertion point property, but i haven't been able to do it. I know i'm missing something, but can't find what. I'd appreciate some help on this.
I modified you’re a routine a bit, for testing purposes. See if this works any better.
Dim INSPOINT(0 To 2) As Double 'Dim as double array
INSPOINT(2) = 0
   If OBJLAYOUT.Name <> "Model" Then
                   Set MARK = AOBJ
                   MARK.InsertionPoint = INSPOINT 'reset insertion point
               End If
           End If
       Next AOBJ
   End If
Next OBJLAYOUT
MsgBox INSSTR
End Sub
