peterg Posted February 27, 2010 Posted February 27, 2010 Using PEDIT how do I convert a number of lines & arcs into a polyline? Quote
ReMark Posted February 27, 2010 Posted February 27, 2010 Select the option to "join" then choose which lines and arcs (ends must be touching) you wish to join up. If the operation is successful your multiple lines and arcs will be become one entity. Quote
peterg Posted February 27, 2010 Author Posted February 27, 2010 Select the option to "join" then choose which lines and arcs (ends must be touching) you wish to join up. If the operation is successful your multiple lines and arcs will be become one entity. PEDIT polyline or multiple multiple select objects lines selected enter an option which one do I select enter fuzz distance or joint type ? Quote
alanjt Posted February 27, 2010 Posted February 27, 2010 Command: pe PEDIT Select polyline or [Multiple]: m Select objects: Specify opposite corner: 8 found Select objects: Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j Join Type = Extend Enter fuzz distance or [Jointype] <0.0000>: 7 segments added to polyline Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: Quote
peterg Posted February 27, 2010 Author Posted February 27, 2010 Command: pe PEDIT Select polyline or [Multiple]: m Select objects: Specify opposite corner: 8 found Select objects: Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j Join Type = Extend Enter fuzz distance or [Jointype] <0.0000>: 7 segments added to polyline Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: I have tried this several times, but all the lines and arcs are still seperate lines & arcs, not one complete poly line is there something missing????? Quote
alanjt Posted February 27, 2010 Posted February 27, 2010 I have tried this several times, but all the lines and arcs are still seperate lines & arcs, not one complete poly line is there something missing????? Do they all have different elevations? You can't PEdit>Join lines on different elevation planes. Quote
peterg Posted February 27, 2010 Author Posted February 27, 2010 Do they all have different elevations? You can't PEdit>Join lines on different elevation planes. I am drawing in the isometric grid, all the lines are in the same plane at the same height. basically i have plotted 4 circles, drawn tangent lines from circle to circle & trimmed the circles to end up with a rectangle with radius corners. hope this describes it ok Quote
peterg Posted February 27, 2010 Author Posted February 27, 2010 Command: pe PEDIT Select polyline or [Multiple]: m Select objects: Specify opposite corner: 8 found Select objects: Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j Join Type = Extend Enter fuzz distance or [Jointype] <0.0000>: [i][color=red]After I press enter at this point, my command line says [/color][/i] [i][/i] [color=#ff0000]0 segments added to polyline[/color] 7 segments added to polyline Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: please see where I have added red text. Quote
Coosbaylumber Posted February 27, 2010 Posted February 27, 2010 They pretty well got the thing nailed down. But only thing I can think of is if you somehow got double lines. An out and back situation. The arc or line will then easier connect into the second line than to connect up the next line in a series. Thus you actually then are trying to connect in a line into the middle of one section, or you may be trying to connect in a rectangle to the figure. In either situation, it can't be done. Wm. Quote
ReMark Posted February 27, 2010 Posted February 27, 2010 Why not try drawing the rectangle first (remember to use OSnaps) then fillet the corners? Quote
peterg Posted February 27, 2010 Author Posted February 27, 2010 Why not try drawing the rectangle first (remember to use OSnaps) then fillet the corners? I know I said rectangle, but that was for ease of explanation, it actually has a shaped perimeter. I have just drawn a rectangle & filleted the corners & that has converted to a polyline, so I must have missed something on my original drawing, I am now going back to check. Quote
