Selecting specific text
Does anyone know how I can select specific text, such as text that beings with bw and change to a layer.....
I was having a look at the object selection filter and qselect but can't seem to get anywhere.
SSX doesn't have anything either....
Cheers
this worked the few times I tried it, not a whole lot of error control...
(defun c:test (/ pre prelen ln  ss idx cnt obj)
 (vl-load-com)
 (setq pre (getstring "\nEnter prefix (case sensitive):")
   prelen (strlen pre)
   ln (getstring "\nEnter Layer name: ")
 (if (not (tblsearch "layer" ln))
   (princ "\nLayer does not exist")
   (setq ss (ssget "X" '((0 . "*TEXT")))
     idx 0
     cnt 0)
 (repeat (sslength ss)
   (setq obj (vlax-ename->vla-object (ssname ss idx))
   (if
     (= pre (substr (vlax-get obj 'Textstring) 1 prelen))
     (vlax-put obj 'Layer ln)
     (setq cnt (1+ cnt))
   (setq idx (1+ idx))
   (princ (strcat "\n" (itoa cnt) " text entities moved to layer " ln))
Why use lisp when Acad has the ability built in...
use Geobuilder's suggestion below
quick select -> Properties [Contents] -> The operator [* search with global symbols] -> Value [bw*] -> Ok )Translation can be not exact, look on sense)
How does that lsp routine work am i required to alter anything....I tried entering but it didn't work, can you explain a little better???
And the quick select doesn't work either, I'm using 2010 - this is what I selected
Apply to: entire drawing
Object type: Mtext
Properties: Contents
Operator: *
Value: BW*
Command line:
Command: _.QSELECT
0 item(s) selected.
