raj banerjee Posted August 19, 2008 Posted August 19, 2008 i have created a table style and saved it within a drawing, how would i go about adding this style to a tool palette? any help would be great:) Quote
feargt Posted July 23, 2013 Posted July 23, 2013 On the toolpalette create a macro that will insert this drawing into your current drawing and then delete the "block", this will bring in all styles (text, dim, multileader, tables etc) into your current drawing. Save the drawing with the styles in a support path of AutoCAD. ^C^C_insert "MY_Styles" 0,0;;;;_erase;L;; Quote
SunnyTurtle Posted July 23, 2013 Posted July 23, 2013 Thanks I ended up just saving as a block in a drawing and used design centre to create a toolpallet from that drawing. I then went into the property in the toolpallet and made it explode the block after inserting This also gave me the added advantage of a template that I can match my tables to. Thanks for you advice I will be sure to use it in the future. Quote
tzframpton Posted July 23, 2013 Posted July 23, 2013 Thanks I ended up just saving as a block in a drawing and used design centre to create a toolpallet from that drawing. I then went into the property in the toolpallet and made it explode the block after inserting This also gave me the added advantage of a template that I can match my tables to. Thanks for you advice I will be sure to use it in the future. This is how we do it and is the best method without going into any custom programming or macros. Quote
