blazejjj Posted March 1, 2010 Posted March 1, 2010 Hey I recently started working in a Swiss office that has a German version of Autocad (LT 2008). I am used to English shortcuts but am not very happy to manually edit each command in the Command Alias Editor. I imagine I am not the only person that has ever had such a problem so thought maybe someone has an acad.pgp file with English shortcuts for a German Autocad. Guess each person might have slightly different shortcuts but the core is the same and would save me hours of boring typing. Thanks in advance Blazej Quote
dbroada Posted March 7, 2010 Posted March 7, 2010 I thought that you could precede the commands with an underscore or dot (or both) to call the native English command. You should then be able to do a find|replace on your existing pgp file using wordpad rather than the command alias editor. Quote
rkent Posted March 7, 2010 Posted March 7, 2010 The dot gives you the command even if it has been redefined. The underscore give you the English command. Quote
