Is there a routine to convert all text to uppercase?
Have you tried Express Tools' Tcase command?
Do you mean an AutoLISP statement (saw from your previous posts that you are doing programming)? If yes, is STRCASE the one that you are looking for.
Regards,
lpseifert
Yes Its what I am looking for
msasu
I am new in programing (this routine is first one I did).
In this case I want to select a text then change one of properties
Highlight the text, hold down "shift" "ctrl" and press "u". this should change the text to upper or lower case.
I should really start taking a minute to read the post.
