Hello,
How do I add a pattern to an existing wall? (Wall Styles)
How do I add additional patterns?
Thanks, zionshea
I managed to add styles from the library - still I would appreciate if anyone could help in explaining how for example I can change the pattern of a internal wall of an exusting style.
How can I add a pattern of a grass to a certain masselement?
Go to style mananger and find the wall type. Go to the display properties tab. You can add hatches to individual componants, or to the whole wall width via a "shrinkwrap" hatch
Within each material you assign a wall you have control of the hatches that particular material shows as well. This would be under the wall style, materials tab, and then under the right there is a button to modify the material. Under the material options you would turn on plan hatch, and then the second tab allows you to set the hatch
