I messing around witht he elevation views. We usually show a ground line representing finish grad then dash the footing below. how do i do this in the elevation view? Is there a way to have it show as dashed ? also with the foundation it shows cmu hatching. i want to turn thi soff but i just want to see footings dashed below grade.
Unless I am modeling the terrain which is rare,
I usually just draw a white filled region depicting
the ground plane. I use a heavy line for the
ground plane then invisible lines for the rest
of the region. Then you can draw over the
filled region with dashed lines to show the
foundation.
Maybe it is too much of a throwback to
traditional drafting but it is quick and easy...
on to the details.
