kc27315 Posted August 19, 2008 Posted August 19, 2008 I'm using civil 3d. I have a surface that extends in all directions from the subdivision boundary, but I only want to show contours to the subdivision boundary. I've drawn a polyline around the subdivision boundary, and I want to use this polyline as the boundary for the surface. Can someone guide me through how I might do this. Thank you for any help. kc Quote
kc27315 Posted August 19, 2008 Author Posted August 19, 2008 I found it! Just go under your surface in the prospector bar, and then go under "definition", and click on "boundaries", and then click add, and give it a name. then click "ok", and select your polyline. All done. Thank you. kc Quote
