Is it programatically possible to 'copy' something from the command line, such as a generated file path?
I would then like to manually 'paste' it into another application.
Yes it is possible. Highlight, right-click, select copy. Then go paste to your heart's content.
You can also press the F2 key and see what you have typed and AutoCAD's responses in the AutoCAD Text Window. You can even scroll forward and backwards through contents of the window too.
OK. I think I read the post too quickly.
I still bet there is a way to do it programmatically(sic)? Is that a word?
I believe it is difficult :geek:
How using/reading the logfile?
Example:
(defun c:test nil
 (setvar 'logfilemode 1)
 (print "This is a test")
 (setvar 'logfilemode 0)
 (startapp "notepad" (getvar 'logfilename))
 (princ))
I may be missing something, but I cannot think of another way at the moment.
Thanks Lee -
I was trying marry code your code with mine.
I would like to paste the name and file path into an email
(the earlier post I had seemed not possible)
Its just too hard to go from acad to email.
Thats why I want to paste manually
So this is what I have....
(defun C:CurNamePath
(/ acadx doc dwg )
(vl-load-com)
(setq acadx (vlax-get-acad-object)
doc (vla-get-activedocument acadx)
dwg (vla-get-name doc)
path (vla-get-path doc)
);setq
(princ (strcat path dwg ))
There's no need to paste it to the command line, how about using these treats from Michael Puckett :)
;;  MP
;;  http://www.theswamp.org/index.php?topic=21764.msg263322#msg263322
(defun _SetClipBoardText ( text / htmlfile result )
   ;;  Caller's sole responsibility is to pass a
   ;;  text string. Anything else? Pie in face.
   (setq result
       (vlax-invoke
           (vlax-get
               (vlax-get (setq htmlfile (vlax-create-object "htmlfile")) 'ParentWindow)
              'ClipBoardData
          'SetData  "Text"  text)
   (vlax-release-object htmlfile)
   text
;;  MP
(defun _GetClipBoardText( / htmlfile result )
   (setq result
       (vlax-invoke
           (vlax-get
              'ClipBoardData
          'GetData "Text")
   result
Thanks Lee and Mr Puckett works sweet.:D
Just for those that might be interested in using it-
here is the final code:
;Small Fish
(/ acadx doc dwg htmlfile result )
(vl-load-com)
);setq
(princ (strcat path "\\"  dwg ))
(setq text (strcat path "\\" dwg ))
(SetClipBoardText text)
(princ "\nThe above line has been copied. You can now ")
(princ "\npaste into an email or any other application." )
);defun
;Michael Puckett
(defun SetClipBoardText ( text / htmlfile result )
(setq result
(vlax-invoke
(vlax-get
'ClipBoardData
text
;; Michael Puckett
(defun GetClipBoardText( / htmlfile result )
(setq result
(vlax-invoke
(vlax-get
'ClipBoardData
'GetData "Text")
result
...sorry for the double posting - I just deleted it...
