Thanks a lot.
I tested the routine again.
I found that if my axis be a polyline, the routine cann't display all distances between two intersections (such as lines and curves) and just display distance between them.
Is my conclusion ture?
Do you mean when using a UCS other than World?
  • Replies 49
  • Lee Mac
    22
  • kasra
    9
  • alanjt
    7
  • pontifex
    6
Posted Images
No. I mean if my centerline(axis) is polyline, the routine doesn't work properly.
The routine works with all types of Polyline, Lines, Circles, Arcs, Splines etc . I cannot get it to fail in testing - could you provide a drawing in which you believe it is failing?
I attached a dwg file that i tested it.
test.dwg
I cannot understand why you feel the function is failing, your drawing correctly displays the distances between each intersection and to the end of the curve. :huh:
The points at which your leaders are pointing to are not the Start and End points of the curve, they are just two vertices within the curve. :huh:
Lee
if you explode the red one in drawing and run the routine again, you understand what i mean. i need this situation in my work.
You didn't mention anything about exploding the curve - when exploded and running the routine, it will return the measurements as per your magenta dimensions in the earlier post.
You say:
...the routine doesn't work properly.
I don't see how you have reached this conclusion, when the routine clearly displays the correct measurements for every selected curve - you have even demonstrated this fact in your example drawing.
I would recommend that you understand the purpose of such a program before making such claims against it.
I'm so surry.
I never mean that.
The routine you provided is so useful for lots of goals.
  • 1 month later...
Hi Lee.
Can you please modify your routine for requesting a selection set instead of entsel???
Hi dear Mac Lee.
What did i do wrong in my drowing?
I used the first routine posted in #35 on the blue line in the attached drawing. It retruns alwayse this error:
** Error: bad argument type: numberp: nil **
Can you help me?
Drawing1.dwg
