Alignment not displaying
Today an alignment my colleague created and had in a drawing would not display. The alignment layer was turned on, and the alignment style was set to display the alignment. I could not find a way to make it visible. It was still part of the drawing as it could be seen in the prospector and could be used to create profiles and sections. Anyone else had this problem before? How can I make this alignment show up? Creating a data shortcut of itself showed the referenced alignment, but this is not really a viable solution.
Okay, that problem was easily solved, he accidentally moved the alignment to another layer and when we turned all layers on it did not show up because we did not regen the drawing. But now when it is xref'd into a layout for a plan and profile drawing the alignment station markers are showing up extremely small, not sure if this is a scaling problem, other drawings work fine.
