MarcoW Posted March 6, 2010 Posted March 6, 2010 In autocad 2008, when making dynamic blocks, at some point you need to save them to your hard drive. I mean, not leaving it in the DWG as it was created, there might be other rubbish in the DWG... With casual blocks I used WBLOCK to do so. With dynamic blocks, I create them with BlockEditor. When it is finished, and I save the file something is going wrong: when I try to insert the block in a new dwg it says: Command: i INSERT Block test_01 references itself *Invalid* I am missing a big thingy over here... can anyone point me in the right direction? Thank you allready. Btw.: I learned there are some cool tutorials on youtube about dynamic blocks... this is a good way to learn at least for me. Quote
MarcoW Posted March 6, 2010 Author Posted March 6, 2010 Reading my own post I read my own lines: With casual blocks I used WBLOCK to do so. Well I tried writing a dynamic block definition with Wblock... it worked. Is this the moment where I need my %$#^kicked? Quote
dbroada Posted March 7, 2010 Posted March 7, 2010 glad you are sorted but for future ref, if you get a "Block references itself" message it is because you have created a block in a drawing and then named that drawing with the same name. In itself this is not a problem. The problem come if you then try to insert that into another drawing. Rather than go into an endless loop AutoCAD just gives the above error. Quote
