Wenndy Posted March 8, 2010 Posted March 8, 2010 Hi everyone ! I'm a new members of this community. I've got a simple question. In our office we have a version of Autocad 2010. One user have a problem with the command "scalelistedit". When he does the reset option the command clean everything but we dont have the imperial list anymore; only the metric version. We work alot in imperial scale and I wonder how to re-insert all the scale into the drawing without to do it manually. Any suggestion anyone ? Thank for the help ! Wenndy Interior designer Montreal, Quebec Quote
Fire_col Posted March 8, 2010 Posted March 8, 2010 Not really sure why were you resetting on the scalelist edit? run the command "-scalelistedit" type r> enter> reset scale list to defaults? [yes/no]>y>enter> exit. that should bring back all of the default scales which include the imperial ones. Quote
Wenndy Posted March 8, 2010 Author Posted March 8, 2010 See That the problem... When I do the reset everything is there except the imperial scale... it dosent appears? Wenndy Quote
rkmcswain Posted March 8, 2010 Posted March 8, 2010 When he does the reset option the command clean everything but we dont have the imperial list anymore; only the metric version. Was this drawing started from a metric template? What is MEASUREMENT set to? Quote
rkmcswain Posted March 8, 2010 Posted March 8, 2010 that should bring back all of the default scales which include the imperial ones.It does, but the "default" list is different, depending on one or more factors. Quote
Wenndy Posted March 8, 2010 Author Posted March 8, 2010 It a Metric files and the unit is set on milimeter. I've check other files if it the same thing and it seem that even if i work in "imperial scale" and do the command -scalelistedit it wont remove the metric default scale. Wenndy Quote
