sadhu Posted March 8, 2010 Posted March 8, 2010 In the code below I have this IF like so (if (= Edit1 "") (progn (Alert "The field is empty") ([color=Red]exit[/color]))) I want to replace "exit" with something that goes back to the Edit1 box (if it is empty) for complilation and get focus there. Edit1 is in a DCL dialog. Maybe something to restart the dialog. ;-------------start dialog------------ (setq dcl_id (load_dialog "hello_sp.dcl")) ; Load the DCL file. (if (not (new_dialog "hello_sp" dcl_id)) ; Initialize the dialog. (exit) ; Exit if this doesn't ; work. ) ;------------ set values in dialog box---- (set_tile "discesa" (rtos a1 2 2)) (set_tile "masetto1" (rtos a2 2 2)) (set_tile "salita" (rtos miodist 2 2)) (set_tile "tolleranza" (rtos tolleranza 2 2)) (set_tile "orriz" (rtos d1 2 2)) (set_tile "note_" "Ricordati bracci per il Q.E. e dorsali") (set_tile "grand_dist" (rtos tot2 2 2)) (set_tile "grand_dist_" "GRAND TOTAL (SQ)") (set_tile "Text1" "Numero Braccio") (set_tile "Edit1" "") (set_tile "Text2" "Diametro Tubo [*=25]") (set_tile "Edit2" "") (set_tile "Text3" "Tipo Linea") (set_tile "Edit3" "") ; Dialog Actions (action_tile "Edit1" "(setq Edit1 $value)") (action_tile "Edit2" "(setq Edit2 $value)") (action_tile "Edit3" "(setq Edit3 $value)") ;------------ end - set values in dialog box---- (start_dialog) ; Display the dialog ; box. (if (= Edit1 "") (progn (Alert "Campo No. braccio non puo essere vuoto") (exit))) (unload_dialog dcl_id) ; Unload the DCL file. (princ) Quote
BearDyugin Posted March 8, 2010 Posted March 8, 2010 (action_tile "Edit1" "(if (= (setq Edit1 $value) \"\") (progn (Alert \"The field is empty\") (mode_tile \"Edit1\" 2) ) )" ) Quote
sadhu Posted March 8, 2010 Author Posted March 8, 2010 I copied your code (action_tile "Edit1" "(if (= (setq Edit1 $value) \"\") (progn (Alert \"The field is empty\") (mode_tile \"Edit1\" 2) ) )" ) and replaced (action_tile "Edit1" "(setq Edit1 $value)") I get this error in the build output. [CHECKING TEXT sq - D_30_MAS_30_TOL_20 text.lsp loading...]. ; warning: too many arguments: (ACTION_TILE "Edit1" "(if (= (setq Edit1 $value) \"\")\n (progn\n (Alert " THE ... ) .. ; Check done. Quote
BearDyugin Posted March 9, 2010 Posted March 9, 2010 of course, because You have passed a slash \ which is necessary for that inverted commas " were perceived as inverted commas in a string, a part of a stringe, instead of its end [CHECKING TEXT sq - D_30_MAS_30_TOL_20 text.lsp loading...]. ; warning: too many arguments: (ACTION_TILE "Edit1" "(if (= (setq Edit1 $value) \"\")\n(progn\n (Alert \" THE ... ) .. ; Check done. Not to suffer with slashes and inverted commas and as that habitual formatting that is written in action_tile, it is possible to write down so (action_tile "Edit1" (vl-prin1-to-string (quote (if (= (setq Edit1 $value) "") (progn (Alert "The field is empty") (mode_tile "Edit1" 2) ) ) ) ) ) And for good, it is necessary on Ok to write so (action_tile "accept" (vl-prin1-to-string (quote (if Edit1 (done_dialog) (progn (Alert "The field of Edit1 is empty") (mode_tile "Edit1" 2) ) ) ) ) ) Quote
sadhu Posted March 9, 2010 Author Posted March 9, 2010 I can't get it to work. The "if" command does not notice that the edit1 is empty and the program proceeds normal. I copied this code : (action_tile "Edit1" (vl-prin1-to-string (quote (if (= (setq Edit1 $value) "") (progn (Alert "The field is empty") (mode_tile "Edit1" 2) ) ) ) ) ) and inserted it like this : ;-------------start dialog------------ (setq dcl_id (load_dialog "hello_sp.dcl")) ; Load the DCL file. (if (not (new_dialog "hello_sp" dcl_id)) ; Initialize the dialog. (exit) ; Exit if this doesn't ; work. ) ;------------ set values in dialog box---- (set_tile "discesa" (rtos a1 2 2)) (set_tile "masetto1" (rtos a2 2 2)) (set_tile "salita" (rtos miodist 2 2)) (set_tile "tolleranza" (rtos tolleranza 2 2)) (set_tile "orriz" (rtos d1 2 2)) (set_tile "note_" "Ricordati bracci per il Q.E. e dorsali") (set_tile "grand_dist" (rtos tot2 2 2)) (set_tile "grand_dist_" "GRAND TOTAL (SQ)") (set_tile "Text1" "Numero Braccio") (set_tile "Edit1" "") (set_tile "Text2" "Diametro Tubo [*=25]") (set_tile "Edit2" "") (set_tile "Text3" "Tipo Linea") (set_tile "Edit3" "") ; Dialog Actions (action_tile "Edit1" "(setq Edit1 $value)") (action_tile "Edit2" "(setq Edit2 $value)") (action_tile "Edit3" "(setq Edit3 $value)") ;------------ end - set values in dialog box---- (start_dialog) ; Display the dialog ; box. [color=Red](action_tile "Edit1" (vl-prin1-to-string (quote (if (= (setq Edit1 $value) "") (progn (Alert "The field is empty") (mode_tile "Edit1" 2) ) ) ) )[/color] [color=Red]) [/color] ;(if (= Edit1 "") ; (progn ; (Alert "Campo No. braccio non puo essere vuoto") ;(exit))) (unload_dialog dcl_id) ; Unload the DCL file. (princ) Quote
Lee Mac Posted March 9, 2010 Posted March 9, 2010 I think: (action_tile "Edit1" (vl-prin1-to-string (quote (progn (if (= (setq Edit1 $value) "") (progn (Alert "The field is empty") (mode_tile "Edit1" 2))))))) Quote
sadhu Posted March 9, 2010 Author Posted March 9, 2010 Lee, I placed your code as below but "if" does not "notice" that Edit1 box is empty. Just to let you know - your code is inserted between the start dialog and unload dialog commands. (I tried it inserted before the start dialog too) like this : (setq dcl_id (load_dialog "hello_sp.dcl")) ; Load the DCL file. (if (not (new_dialog "hello_sp" dcl_id)) ; Initialize the dialog. (exit) ; Exit if this doesn't ; work. ) ;------------ set values in dialog box---- (set_tile "discesa" (rtos a1 2 2)) (set_tile "masetto1" (rtos a2 2 2)) (set_tile "salita" (rtos miodist 2 2)) (set_tile "tolleranza" (rtos tolleranza 2 2)) (set_tile "orriz" (rtos d1 2 2)) (set_tile "note_" "Ricordati bracci per il Q.E. e dorsali") (set_tile "grand_dist" (rtos tot2 2 2)) (set_tile "grand_dist_" "GRAND TOTAL (SQ)") (set_tile "Text1" "Numero Braccio") (set_tile "Edit1" "") (set_tile "Text2" "Diametro Tubo [*=25]") (set_tile "Edit2" "") (set_tile "Text3" "Tipo Linea") (set_tile "Edit3" "") ; Dialog Actions (action_tile "Edit1" "(setq Edit1 $value)") (action_tile "Edit2" "(setq Edit2 $value)") (action_tile "Edit3" "(setq Edit3 $value)") ;------------ end - set values in dialog box---- (start_dialog) ; Display the dialog box. [color=Red](action_tile "Edit1" (vl-prin1-to-string (quote (progn (if (= (setq Edit1 $value) "") (progn (Alert "The field is empty") (mode_tile "Edit1" 2)))))))[/color] ;(if (= Edit1 "") ;(progn ;(Alert "Campo No. braccio non puo essere vuoto") ;(exit))) (unload_dialog dcl_id) ; Unload the DCL file. (princ) ;(setq lay "RH MEASURE Layer" );- writes total value to drawing Layer ;(alert "Inserisci NUMERO BRACCIO / [*] DIA.TUBO 25 - TIPO LINEA ") ;(setq braccio (getstring "\nInserisci NUMERO BRACCIO / [*] DIA.TUBO 25 - TIPO LINEA :")) (and (setq pnt (getpoint "\nPunto di inserimento misura / Specify Text placement point: ")) (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") ;(cons 8 lay) (cons 1 (strcat "(" Edit1 Edit2 ")" (rtos tot2 2 2) Edit3)) (cons 7 (getvar 'textstyle)) (cons 10 pnt) (cons 40 0.08) ) ;_ list ) ;_ entmakex ) ;_ and ;------------------------ ) (princ "\nType sq to run Grand Distance(sq)") (princ) Quote
sadhu Posted March 9, 2010 Author Posted March 9, 2010 When I use this - it exists. (if (= Edit1 "") (progn (Alert "Campo R non puo essere vuoto") (exit) )) Quote
sadhu Posted March 9, 2010 Author Posted March 9, 2010 (edited) sadhu, show DCL and LISP entirely dcl : hello_sp : dialog { label = "Sadhu says"; //first box - ** srl : boxed_column { label = "** srl"; //second box - Dati di base //start line 1 : boxed_column { label = "Dati di base"; : row { : column { width = 10; fixed_width = true; : text { key = "discesa_"; label = "Discesa ";// } } : text { key = "discesa"; label = "Sanjay";//Prompt from lsp file width = 18; fixed_width_font = true; } } //spacer; //end line 1 //start line 1 bis : row { : column { width = 10; fixed_width = true; : text { key = "tolleranza_"; label = "Tolleranza ";// } } : text { key = "tolleranza"; label = "San";//Prompt from lsp file width = 18; fixed_width_font = true; } } //spacer; //end line 1 bis //start line 2 : row { : column { width = 10; fixed_width = true; : text { key = "masetto1_"; label = "Masetto_1 ";//Prompt from lsp file } } : text { key = "masetto1"; label = "jay";//Prompt from lsp file width = 18; fixed_width_font = true; } }//end line 2 } //second box - Dati di base //spacer; //third box - dati inseriti : boxed_column { label = "Dati inseriti"; //start salita inserita : row { : column { width = 10; fixed_width = true; : text { key = "Salita_"; label = "Salit�* Inserita";//Prompt from lsp file } } : text { key = "salita"; label = "";//Prompt from lsp file width = 18; fixed_width_font = true; } } //end salita inserita //start distanza orrizontale : row { : column { width = 10; fixed_width = true; : text { key = "orriz_"; label = "Dist Orrizon. ";//Prompt from lsp file } } : text { key = "orriz"; label = "";//Prompt from lsp file width = 18; fixed_width_font = true; } } //end distanza orrizontale } // end third box - dati inseriti //spacer; spacer; spacer; spacer; //start fourth box Grand : boxed_column { //start last line Grand : row { : column { width = 10; fixed_width = true; : text { key = "grand_dist_"; label = "GRAND TOTAL ";//Prompt from lsp file } } : text { key = "grand_dist"; label = "Sanjay";//Prompt from lsp file width = 18; fixed_width_font = true; } } //end last line Grand } //endt fourth box Grand //start insert numero braccio / tubo / linee : row {//< fixed_width = true; : column { width = 35; fixed_width = true; spacer; : text { key = "Text1"; label = "";//Text1$ from lsp file } } : edit_box { key = "Edit1";//Edit1$ from lsp file edit_width = 9.42; fixed_width = true; allow_accept = true; initial_focus = true; } }//> : row {//< fixed_width = true; : column { width = 35; fixed_width = true; spacer; : text { key = "Text2"; label = "";//Text2$ from lsp file } } : edit_box { key = "Edit2";//Edit2$ from lsp file edit_width = 9.42; fixed_width = true; } }//> : row {//< fixed_width = true; : column { width = 35; fixed_width = true; spacer; : text { key = "Text3"; label = "";//Text3$ from lsp file } } : edit_box { key = "Edit3";//Edit3$ from lsp file edit_width = 9.42; fixed_width = true; } }//> //end insert numero braccio / tubo / linee } //end last line Grand spacer; spacer; spacer; spacer; spacer; spacer; : button { key = "accept"; label = "OK"; is_default = true; width = 18; fixed_width = true; alignment = centered; } //end button //start note : row { : column { width = 10; fixed_width = true; : text { key = "note_"; label = "Note: ";//Prompt from lsp file width = 40; fixed_width_font = true; } } //end note spacer; spacer; spacer; spacer; } //end fourth box Grand } //end first box - rh srl lisp : in red is what I want to replace (exit) ;rev 300.1.2prad ;cumulative distance ;this routine is just like the Autocad Distance command with the ;exception that it allows you to pick more than 2 consecutive points. ;the routine will display the cumulative distance and the distance ;between the last two points picked on the command line. ; allows constants and keyboard input (defun c:sq () ;(/ Edit1 Edit2 Edit3) (setvar "cmdecho" 0) (graphscr) (setq a1 0.23 ; discesa da PT a2 0.15 ; massetto 1 a3 0.15 ; massetto 2 tolleranza 0.201 ; valore aggiunto alla misura totale Edit1 "" Edit2 "" Edit3 "") ;-------------------- (setq p1 (getpoint "\nPick start point (SQ)") p2 (getpoint p1 "\nPick next point (SQ)") d1 (distance p1 p2) prdist (strcat "\nDistance: " (rtos d1)) ) (princ prdist) (setq p3 (getpoint p2 "\nPick next point (SQ) or RETURN if done ")) (while p3 (setq d0 (distance p2 p3) d1 (+ (distance p2 p3) d1) p2 p3 prdist (strcat "\nDistance: " (rtos d0) ", Cumulative distance: " (rtos d1)) ) (princ prdist) (setq p3 (getpoint p2 "\nPick Next Point (SQ)")) ) (setq cumd (strcat "Distanza orrizontale --> " (rtos d1 2 2))) (prompt cumd) (princ) (setq miodist (getdist "\n Insert Height ")) (princ "\n The height is ") (princ (rtos miodist 2 2)) (princ) (setq tot2 (+ a1 a2 a3 tolleranza miodist d1)) (setq pcumd (strcat "Grand distance(SQ) --> " (rtos tot2 2 2))) (princ "\n --> ") (prompt pcumd) (princ) ;-------------start dialog------------ (setq dcl_id (load_dialog "hello_sp.dcl")) ; Load the DCL file. (if (not (new_dialog "hello_sp" dcl_id)) ; Initialize the dialog. (exit) ; Exit if this doesn't ; work. ) ;------------ set values in dialog box---- (set_tile "discesa" (rtos a1 2 2)) (set_tile "masetto1" (rtos a2 2 2)) (set_tile "salita" (rtos miodist 2 2)) (set_tile "tolleranza" (rtos tolleranza 2 2)) (set_tile "orriz" (rtos d1 2 2)) (set_tile "note_" "Ricordati bracci per il Q.E. e dorsali") (set_tile "grand_dist" (rtos tot2 2 2)) (set_tile "grand_dist_" "GRAND TOTAL (SQ)") (set_tile "Text1" "Numero Braccio") (set_tile "Edit1" "") (set_tile "Text2" "Diametro Tubo [*=25]") (set_tile "Edit2" "") (set_tile "Text3" "Tipo Linea") (set_tile "Edit3" "") ; Dialog Actions (action_tile "Edit1" "(setq Edit1 $value)") (action_tile "Edit2" "(setq Edit2 $value)") (action_tile "Edit3" "(setq Edit3 $value)") ;------------ end - set values in dialog box---- (start_dialog) ; Display the dialog box. [color=Red](if (= Edit1 "");(progn (Alert "Campo No. braccio non puo essere vuoto") ;(exit)))[/color] (unload_dialog dcl_id) ; Unload the DCL file. (princ) ;(setq lay "RH MEASURE Layer" );- writes total value to drawing Layer ;(alert "Inserisci NUMERO BRACCIO / [*] DIA.TUBO 25 - TIPO LINEA ") ;(setq braccio (getstring "\nInserisci NUMERO BRACCIO / [*] DIA.TUBO 25 - TIPO LINEA :")) (and (setq pnt (getpoint "\nPunto di inserimento misura / Specify Text placement point: ")) (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") ;(cons 8 lay) (cons 1 (strcat "(" Edit1 Edit2 ")" (rtos tot2 2 2) Edit3)) (cons 7 (getvar 'textstyle)) (cons 10 pnt) (cons 40 0.08) ) ;_ list ) ;_ entmakex ) ;_ and ;------------------------ ) (princ "\nType sq to run Grand Distance(sq)") (princ) Edited October 10, 2012 by sadhu Quote
BearDyugin Posted March 9, 2010 Posted March 9, 2010 ;rev 300.1.2prad ;cumulative distance ;this routine is just like the Autocad Distance command with the ;exception that it allows you to pick more than 2 consecutive points. ;the routine will display the cumulative distance and the distance ;between the last two points picked on the command line. ; allows constants and keyboard input (defun c:sq () ;(/ Edit1 Edit2 Edit3) (setvar "cmdecho" 0) (graphscr) (setq a1 0.23 ; discesa da PT a2 0.15 ; massetto 1 a3 0.15 ; massetto 2 tolleranza 0.201 ; valore aggiunto alla misura totale Edit1 "" Edit2 "" Edit3 "" ) ;-------------------- (setq p1 (getpoint "\nPick start point (SQ)") p2 (getpoint p1 "\nPick next point (SQ)") d1 (distance p1 p2) prdist (strcat "\nDistance: " (rtos d1)) ) (princ prdist) (setq p3 (getpoint p2 "\nPick next point (SQ) or RETURN if done ")) (while p3 (setq d0 (distance p2 p3) d1 (+ (distance p2 p3) d1) p2 p3 prdist (strcat "\nDistance: " (rtos d0) ", Cumulative distance: " (rtos d1) ) ) (princ prdist) (setq p3 (getpoint p2 "\nPick Next Point (SQ)")) ) (setq cumd (strcat "Distanza orrizontale --> " (rtos d1 2 2))) (prompt cumd) (princ) (setq miodist (getdist "\n Insert Height ")) (princ "\n The height is ") (princ (rtos miodist 2 2)) (princ) (setq tot2 (+ a1 a2 a3 tolleranza miodist d1)) (setq pcumd (strcat "Grand distance(SQ) --> " (rtos tot2 2 2))) (princ "\n --> ") (prompt pcumd) (princ) ;-------------start dialog------------ (setq dcl_id (load_dialog "hello_sp.dcl" ) ) ; Load the DCL file. (if (not (new_dialog "hello_sp" dcl_id)) ; Initialize the dialog. (exit) ; Exit if this doesn't ; work. ) ;------------ set values in dialog box---- (set_tile "discesa" (rtos a1 2 2)) (set_tile "masetto1" (rtos a2 2 2)) (set_tile "salita" (rtos miodist 2 2)) (set_tile "tolleranza" (rtos tolleranza 2 2)) (set_tile "orriz" (rtos d1 2 2)) (set_tile "note_" "Ricordati bracci per il Q.E. e dorsali") (set_tile "grand_dist" (rtos tot2 2 2)) (set_tile "grand_dist_" "GRAND TOTAL (SQ)") (set_tile "Text1" "Numero Braccio") (set_tile "Edit1" "") (set_tile "Text2" "Diametro Tubo [*=25]") (set_tile "Edit2" "") (set_tile "Text3" "Tipo Linea") (set_tile "Edit3" "") ; Dialog Actions [color="Red"](action_tile "Edit1" (vl-prin1-to-string (quote (if (= (setq Edit1 $value) "") (progn (Alert "The field is empty") (mode_tile "Edit1" 2) ) ) ) ) ) (action_tile "accept" (vl-prin1-to-string (quote (if (/= Edit1 "") (done_dialog) (progn (Alert "The field of Edit1 is empty") (mode_tile "Edit1" 2) ) ) ) ) )[/color] (action_tile "Edit2" "(setq Edit2 $value)") (action_tile "Edit3" "(setq Edit3 $value)") ;------------ end - set values in dialog box---- (start_dialog) ; Display the dialog box. (if (= Edit1 "") ;(progn (Alert "Campo No. braccio non puo essere vuoto") ) ;(exit))) (unload_dialog dcl_id) ; Unload the DCL file. (princ) ;(setq lay "RH MEASURE Layer" );- writes total value to drawing Layer ;(alert "Inserisci NUMERO BRACCIO / [*] DIA.TUBO 25 - TIPO LINEA ") ;(setq braccio (getstring "\nInserisci NUMERO BRACCIO / [*] DIA.TUBO 25 - TIPO LINEA :")) (and (setq pnt (getpoint "\nPunto di inserimento misura / Specify Text placement point: " ) ) (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") ;(cons 8 lay) (cons 1 (strcat "(" Edit1 Edit2 ")" (rtos tot2 2 2) Edit3)) (cons 7 (getvar 'textstyle)) (cons 10 pnt) (cons 40 0.08) ) ;_ list ) ;_ entmakex ) ;_ and ;------------------------ ) (princ "\nType sq to run Grand Distance(sq)") (princ) Quote
sadhu Posted March 9, 2010 Author Posted March 9, 2010 Thanks Geo. That's exactly how I wanted it work. Evidently I did not use both the code blocks that you had uploaded. Quote
sadhu Posted March 9, 2010 Author Posted March 9, 2010 How can I set focus to edit1 box when the dialog box opens for input? Quote
BearDyugin Posted March 9, 2010 Posted March 9, 2010 How can I set focus to edit1 box when the dialog box opens for input? [quote name=help ]mode_tile Sets the mode of a dialog box tile (mode_tile key mode) Arguments key A string that specifies the tile. The key argument is case-sensitive. mode An integer that can be one of the following: 0 Enable tile 1 Disable tile 2 Set focus to tile 3 Select edit box contents 4 Flip image highlighting on or off Return Values nil ... (set_tile "Edit3" "") [b][color="Red"](mode_tile "Edit1" 2)[/color][/b] ; Dialog Actions ... Quote
sadhu Posted March 9, 2010 Author Posted March 9, 2010 Thanks again Geo .It works. This may sound dumb but actually I did read help and tried to work it out -- inserting mode_tile inside action_tile etc. etc. #@#@ and couldn't find a way out and got "LOST" (how I wish I was on that island ...). Quote
Lee Mac Posted March 9, 2010 Posted March 9, 2010 Glad you got it sorted in the end Sadhu - I didn't have to time today to help further - nice one Geo Quote
