rlshound Posted March 9, 2010 Posted March 9, 2010 Hello Fellow LDDers, I am happy to tell you that I have my point groups and description keys set up. When I import a csv file the points are filtered to the respective point groups,symbols appear and everything gets placed on the proper layer. My next hurdle is to figure out how to generate line work from the field codes. Our field codes have the B,E,BC,EC parameters to begin a line,end a line,begin a curve,end a curve...attached to them...for example...code BB means bottom of bank...to start a line the field surveyor enters BB B to begin the line describing the bottom of the bank and BB E to end and so on...Can AutoCAD process these codes to automatically generate line work. We currently collect GPS data with survey controller and process through a feature code library in TGO.This produces linework which we then export a DXF to use as a XREF to help draw in lines. Does LDD 2008 have the capacity to do this? Is there a lsp routine that generates linework from points without going from point to point? Any help would be appreciated. Thanks...Its been raining here in Phoenix for about a week...very strange for the desert...See You, rlshound Quote
