jimwithaj Posted March 10, 2010 Posted March 10, 2010 Hi, I am after a lisp routine that will enter the area of a selected closed polyline, with the area being a field so if the polyline is altered, so is the area text. So far so easy I'm sure you guys are thinking but I would like a few more bells and whistles:shock:! I would like the area to be shown in m² and to the nearest whole number if it is less than 1 hectare. Once it is greater than or equal to 1ha I would like the number to be shown as X.xxha (eg divide the area by 10,000 and show to 2 decimal places). Thats the bells taken care of, now the whistle! I would like also to be prompted for the Lot number, which once I enter it, it adds that into the multiline text. If I enter nothing I would like it to just display the area. So, for example, if I have an object which is 10,357m². I run the lisp, click on the object, it prompts for a Lot number, I enter in 2 say and then the lisp prompts me where to place the text. I select the spot and the centered multiline text entered is Lot 2 1.36ha (with Lot 2 being on one line and 1.36ha on the line below). What a mouthful! and thanks in advance for your help. It never ceases to amaze me that people are willing to do this just for the craic. Quote
lpseifert Posted March 10, 2010 Posted March 10, 2010 Post the code that you're working on and maybe some one here can offer some advice. Quote
jimwithaj Posted March 10, 2010 Author Posted March 10, 2010 I saw this that was posted by Fixo, in cadtutor thread 23057 (defun C:FA (/ acsp adoc cpt elist en ent fld lead_obj lpt mtx oid osm) (vl-load-com) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) ) (if (and (= (getvar "tilemode") 0) (= (getvar "cvport") 1) ) (setq acsp (vla-get-paperspace adoc)) (setq acsp (vla-get-modelspace adoc)) ) (setq osm (getvar "osmode")) (setvar "osmode" 0) (while (setq ent (entsel "\nSelect pline or hit Enter to exit")) (setq en (car ent)) (if (wcmatch (cdr (assoc 0 (setq elist (entget en)))) "*POLYLINE") (progn (setq cpt (trans (cadr ent)1 0) lpt (trans (getpoint cpt "\nPick the ending point of leader:") 1 0) ) (setq oID (vla-get-objectid (vlax-ename->vla-object en))) (setq fld (strcat (strcat "Area = " "%<\\AcObjProp Object(%<\\_ObjId " (itoa oID) ">%).Area \\f \"%lu2%pr2\">%" "\\P") (strcat "Perimeter = " "%<\\AcObjProp Object(%<\\_ObjId " (itoa oID) ">%).Length \\f \"%lu2%pr2\">%")) ) (setq mtx (vlax-invoke acsp 'AddMText lpt 0.0 fld) ) (vlax-put mtx 'AttachmentPoint (cond ((> (car cpt) (car lpt)) 6 ) ((< (car cpt) (car lpt)) 4 ) (T 4) ) ) (vlax-put mtx 'Height (getvar "textsize")) (setq lead_obj (vlax-invoke acsp 'Addleader (apply 'append (list cpt lpt)) mtx acLineWithArrow ) ) (vlax-put lead_obj 'VerticalTextPosition 0);1 ) ) ) (setvar "osmode" osm) (princ) ) (princ "\n Start command with FA ...") (princ) and also this from wizman (cadtutor thread 32396) who altered a lisp called AreaRon (tip 2292 from cadtips) but I couldn't get this to work in 2010 T 07/08 www.cadalyst.com/code ;;; Tip 2292: AreaRon.lsp Area of Closed Polylines (c) 2008 Ronald Maneja (Wizman) ;;; PRODUCES TEXT CONTAINING AREA OF SELECTED CLOSED POLYLINES ;;; AND PUTS THEM IN AREARON LAYER ;;; CREATED BY RON MANEJA 31JAN08 ;;; USER INPUTS: SCALE, POLYLINE SELECTION ;;; ;;; VERSION 1.1 (09FEB09): ADDED AREA FOR REGIONS, SPLINE, CIRCLE & ELLIPSE ;;; (defun C:AREARON (/ allx ally areaobj counter ctr el entity-name entnamevla mysset prec_temp pt reg_centroid temp tst vertex x y oldlayer oldsnap temperr traperror blpt cir_center el_center maxpt minpt spl_center trpt ) (defun set_var () (setvar 'cmdecho 0) (setq oldlayer (getvar "clayer")) (setq oldsnap (getvar "osmode")) (setq temperr *error*) (setq *error* traperror) (setvar "osmode" 0) ) (defun traperror (errmsg) (command nil nil nil) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg)) ) (command "_.undo" "end") (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (setvar "cmdecho" 1) (princ "\nError Resetting Enviroment ") (setq *error* temperr) ) (defun reset_var () (setq *error* temperr) (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (command "_.undo" "end") (setvar "cmdecho" 1) ) (vl-load-com) (set_var) (command "_.undo" "be") (if (tblsearch "Layer" "AREARON") (command "._layer" "_thaw" "AREARON" "_on" "AREARON" "_unlock" "AREARON" "_set" "AREARON" "") ;_ closes command (command "._layer" "_make" "AREARON" "_color" 1 "AREARON" "") ;_ closes command ) (if (null sch) (setq sch 1.0) ) (initget 6) (setq temp (getreal (strcat "\nENTER SCALE <" (rtos sch 2 2) ">: " ) ) ) (if temp (setq sch temp) (setq temp sch) ) (if (null precision) (setq precision 1) ) (initget 6) (setq prec_temp (getint (strcat "\nHOW MANY DECIMAL PLACES?: <" (rtos precision 2 2) ">: " ) ) ) (if prec_temp (setq precision prec_temp) (setq prec_temp precision) ) (prompt "\nSELECT CLOSED POLYLINES/SPLINES, REGION, CIRCLE & ELLIPSE:> ") (setq mysset (ssget '((-4 . "<or") (-4 . "<and") (0 . "LWPOLYLINE") (70 . 1) (-4 . "and>") (-4 . "<and") (0 . "SPLINE") (70 . 11) (-4 . "and>") (0 . "REGION") (0 . "CIRCLE") (0 . "ELLIPSE") (-4 . "or>") ) ) counter 0 ) (if mysset (progn (while (< counter (sslength mysset)) (setq entity-name (ssname mysset counter) EL (entget entity-name) entnamevla (vlax-ename->vla-object entity-name) areaobj (vla-get-area entnamevla) ) (cond ((eq (cdr (assoc 0 el)) "LWPOLYLINE") (progn (setq allx 0 ally 0 ctr 0 tst 1 ) (while (assoc 10 el) (setq vertex (cdr (assoc 10 el)) ctr (+ ctr 1) x (car vertex) y (cadr vertex) allx (+ allx x) ally (+ ally y) EL (cdr (member (assoc 10 el) el)) ) ) (setq x (/ allx ctr) y (/ ally ctr) pt (list x y) ) (command "text" "j" "mc" pt (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) ((eq (cdr (assoc 0 el)) "REGION") (setq reg_centroid (vlax-safearray->list (vlax-variant-value (vla-get-centroid entnamevla) ) ) ) (command "text" "j" "mc" reg_centroid (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "CIRCLE") (setq cir_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" cir_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "ELLIPSE") (setq el_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" el_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "SPLINE") (vla-GetBoundingBox entnamevla 'minPt 'maxPt) (setq blPt (vlax-safearray->list minPt) trPt (vlax-safearray->list maxPt) ) (setq spl_center (mapcar '* '(0.5 0.5 0.5) (mapcar '+ blPt trPt)) ) (command "text" "j" "mc" spl_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) (setq counter (+ counter 1)) ) ) (alert "\nNO CLOSED POLYLINES/LWPOLYLINES/SPLINES IN YOUR SELECTION" ) ) (reset_var) (princ) ) (prompt "'\n>>>...AreaRon.Lsp is now Loaded, Type 'Arearon' to start command...<<<") (princ) Unfortunately for myself, I can't understand lisp scripting at all , macro's are as far as i can extend to! Cheers for your help Quote
alanjt Posted March 10, 2010 Posted March 10, 2010 Creating a field is extremely easy. The easiest thing to do is create the desired field in a piece of MText then use (vla-fieldcode (vlax-ename->vla-object (car (entsel)))) This will give you the desired coding, all you have to do then is remove the the object id number string and strcat the remaining together with the (itoa (vla-get-objectid (vlax-ename->vla-object (car (entsel))))) of the desired LWPolyline (in this case). This is a fairly simple routine to write. You should give it a shot. Quote
vanhuyou Posted June 6 Posted June 6 (edited) On 3/10/2010 at 9:53 AM, jimwithaj said: I saw this that was posted by Fixo, in cadtutor thread 23057 (defun C:FA (/ acsp adoc cpt elist en ent fld lead_obj lpt mtx oid osm) (vl-load-com) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) ) (if (and (= (getvar "tilemode") 0) (= (getvar "cvport") 1) ) (setq acsp (vla-get-paperspace adoc)) (setq acsp (vla-get-modelspace adoc)) ) (setq osm (getvar "osmode")) (setvar "osmode" 0) (while (setq ent (entsel "\nSelect pline or hit Enter to exit")) (setq en (car ent)) (if (wcmatch (cdr (assoc 0 (setq elist (entget en)))) "*POLYLINE") (progn (setq cpt (trans (cadr ent)1 0) lpt (trans (getpoint cpt "\nPick the ending point of leader:") 1 0) ) (setq oID (vla-get-objectid (vlax-ename->vla-object en))) (setq fld (strcat (strcat "Area = " "%<\\AcObjProp Object(%<\\_ObjId " (itoa oID) ">%).Area \\f \"%lu2%pr2\">%" "\\P") (strcat "Perimeter = " "%<\\AcObjProp Object(%<\\_ObjId " (itoa oID) ">%).Length \\f \"%lu2%pr2\">%")) ) (setq mtx (vlax-invoke acsp 'AddMText lpt 0.0 fld) ) (vlax-put mtx 'AttachmentPoint (cond ((> (car cpt) (car lpt)) 6 ) ((< (car cpt) (car lpt)) 4 ) (T 4) ) ) (vlax-put mtx 'Height (getvar "textsize")) (setq lead_obj (vlax-invoke acsp 'Addleader (apply 'append (list cpt lpt)) mtx acLineWithArrow ) ) (vlax-put lead_obj 'VerticalTextPosition 0);1 ) ) ) (setvar "osmode" osm) (princ) ) (princ "\n Start command with FA ...") (princ) and also this from wizman (cadtutor thread 32396) who altered a lisp called AreaRon (tip 2292 from cadtips) but I couldn't get this to work in 2010 T 07/08 www.cadalyst.com/code ;;; Tip 2292: AreaRon.lsp Area of Closed Polylines (c) 2008 Ronald Maneja (Wizman) ;;; PRODUCES TEXT CONTAINING AREA OF SELECTED CLOSED POLYLINES ;;; AND PUTS THEM IN AREARON LAYER ;;; CREATED BY RON MANEJA 31JAN08 ;;; USER INPUTS: SCALE, POLYLINE SELECTION ;;; ;;; VERSION 1.1 (09FEB09): ADDED AREA FOR REGIONS, SPLINE, CIRCLE & ELLIPSE ;;; (defun C:AREARON (/ allx ally areaobj counter ctr el entity-name entnamevla mysset prec_temp pt reg_centroid temp tst vertex x y oldlayer oldsnap temperr traperror blpt cir_center el_center maxpt minpt spl_center trpt ) (defun set_var () (setvar 'cmdecho 0) (setq oldlayer (getvar "clayer")) (setq oldsnap (getvar "osmode")) (setq temperr *error*) (setq *error* traperror) (setvar "osmode" 0) ) (defun traperror (errmsg) (command nil nil nil) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg)) ) (command "_.undo" "end") (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (setvar "cmdecho" 1) (princ "\nError Resetting Enviroment ") (setq *error* temperr) ) (defun reset_var () (setq *error* temperr) (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (command "_.undo" "end") (setvar "cmdecho" 1) ) (vl-load-com) (set_var) (command "_.undo" "be") (if (tblsearch "Layer" "AREARON") (command "._layer" "_thaw" "AREARON" "_on" "AREARON" "_unlock" "AREARON" "_set" "AREARON" "") ;_ closes command (command "._layer" "_make" "AREARON" "_color" 1 "AREARON" "") ;_ closes command ) (if (null sch) (setq sch 1.0) ) (initget 6) (setq temp (getreal (strcat "\nENTER SCALE <" (rtos sch 2 2) ">: " ) ) ) (if temp (setq sch temp) (setq temp sch) ) (if (null precision) (setq precision 1) ) (initget 6) (setq prec_temp (getint (strcat "\nHOW MANY DECIMAL PLACES?: <" (rtos precision 2 2) ">: " ) ) ) (if prec_temp (setq precision prec_temp) (setq prec_temp precision) ) (prompt "\nSELECT CLOSED POLYLINES/SPLINES, REGION, CIRCLE & ELLIPSE:> ") (setq mysset (ssget '((-4 . "<or") (-4 . "<and") (0 . "LWPOLYLINE") (70 . 1) (-4 . "and>") (-4 . "<and") (0 . "SPLINE") (70 . 11) (-4 . "and>") (0 . "REGION") (0 . "CIRCLE") (0 . "ELLIPSE") (-4 . "or>") ) ) counter 0 ) (if mysset (progn (while (< counter (sslength mysset)) (setq entity-name (ssname mysset counter) EL (entget entity-name) entnamevla (vlax-ename->vla-object entity-name) areaobj (vla-get-area entnamevla) ) (cond ((eq (cdr (assoc 0 el)) "LWPOLYLINE") (progn (setq allx 0 ally 0 ctr 0 tst 1 ) (while (assoc 10 el) (setq vertex (cdr (assoc 10 el)) ctr (+ ctr 1) x (car vertex) y (cadr vertex) allx (+ allx x) ally (+ ally y) EL (cdr (member (assoc 10 el) el)) ) ) (setq x (/ allx ctr) y (/ ally ctr) pt (list x y) ) (command "text" "j" "mc" pt (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) ((eq (cdr (assoc 0 el)) "REGION") (setq reg_centroid (vlax-safearray->list (vlax-variant-value (vla-get-centroid entnamevla) ) ) ) (command "text" "j" "mc" reg_centroid (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "CIRCLE") (setq cir_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" cir_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "ELLIPSE") (setq el_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" el_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "SPLINE") (vla-GetBoundingBox entnamevla 'minPt 'maxPt) (setq blPt (vlax-safearray->list minPt) trPt (vlax-safearray->list maxPt) ) (setq spl_center (mapcar '* '(0.5 0.5 0.5) (mapcar '+ blPt trPt)) ) (command "text" "j" "mc" spl_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) (setq counter (+ counter 1)) ) ) (alert "\nNO CLOSED POLYLINES/LWPOLYLINES/SPLINES IN YOUR SELECTION" ) ) (reset_var) (princ) ) (prompt "'\n>>>...AreaRon.Lsp is now Loaded, Type 'Arearon' to start command...<<<") (princ) Unfortunately for myself, I can't understand lisp scripting at all , macro's are as far as i can extend to! Cheers for your help Bro can help me change unit mm2 to m2 (second code). Please help me. Thank so much Edited June 6 by vanhuyou Quote
vanhuyou Posted June 6 Posted June 6 On 3/10/2010 at 10:13 AM, alanjt said: Creating a field is extremely easy. The easiest thing to do is create the desired field in a piece of MText then use (vla-fieldcode (vlax-ename->vla-object (car (entsel)))) This will give you the desired coding, all you have to do then is remove the the object id number string and strcat the remaining together with the (itoa (vla-get-objectid (vlax-ename->vla-object (car (entsel))))) of the desired LWPolyline (in this case). This is a fairly simple routine to write. You should give it a shot. Bro how edit code to creat field in mtext. Quote
