asos2000 Posted March 10, 2010 Posted March 10, 2010 what is the possibility of using codes to create a block? I want to avoid inserting a drawing to use the block in dimstyle. DimstyleBlocks.dwg Quote
TimSpangler Posted March 10, 2010 Posted March 10, 2010 Here is an example of creating entities and then creating the block and the insert. This should help you get an understanding of it. FrameCall.lsp Quote
asos2000 Posted March 10, 2010 Author Posted March 10, 2010 the routine not working im using CAD2007 Quote
Lee Mac Posted March 10, 2010 Posted March 10, 2010 This recent thread should help you Asos: http://www.cadtutor.net/forum/showthread.php?t=45495 Quote
fixo Posted March 10, 2010 Posted March 10, 2010 what is the possibility of using codes to create a block?I want to avoid inserting a drawing to use the block in dimstyle. Try it (defun C:add_dimblocks () (if (not (tblsearch "block" "EC-Arrow")) (progn (entmake '((0 . "BLOCK") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockReference") (2 . "EC-Arrow") (10 0 0 0) (70 . 0) ) ) (entmake '((0 . "SOLID") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbTrace") (10 0 0 0) (11 -15 -3.75 0) (12 -15 3.75 0) (13 0 0 0) (39 . 0) ) ) (entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0") ) ) ) ) (if (not (tblsearch "block" "EC_TICK")) (progn (entmake '((0 . "BLOCK") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockReference") (2 . "EC_TICK") (10 0 0 0) (70 . 0) ) ) (entmake '((0 . "LINE") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . (100 . "AcDbLine") (10 0 -6.25 0) (11 0 5 0) ) ) (entmake '((0 . "LINE") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . (100 . "AcDbLine") (10 5 0 0) (11 -5 0 0) ) ) (entmake '((0 . "LINE") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 7) (100 . "AcDbLine") (10 -5 -5 0) (11 5 5 0) ) ) (entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0") ) ) ) ) (princ) ) ~'J'~ Quote
