I want to Add ComboBox Items from Blocks attributes with VBA ,but if it is already added to the ComboBox, i dont want to add it again...
How to do it?
For Each oEnt In oSset
[indent]Set oBlkRef = oEnt
varAtt = oBlkRef.GetAttributes
Set oAtt = varAtt(0)
strAtt = oAtt.TextString
[/indent]
UserForm1.ComboBox1.AddItem strAtt
Next oEnt
valueAlreadyInList = false
For Each item in UserForm1.ComboBox1.items
     If item = strAtt then
           valueAlreadyInList = true
     end if
next
if !valueAlreadyInList then
[/indent]
    end if
Next oEnt
You'll need to change 'Userform1.ComboBox1.items' with the appropriate array member but other than that the above should work
Similarly if you are sorting the contents once the list has been created you could use a loop to remove duplicates
