Write-line lisp???
Guest looseLISPSsinkSHIPS
Hi,
I need a lisp to write a getstring line to the following file.
C:\Drawing Analyser\Signature.txt
I use to have an example file so I know its possible but cant seem to find the example or any new examples on line could somebody please help with this.
I know its got to do with the
(write-line “?????
Thanks-
Its probably better if I talk you through the process, so that you may understand it better.
First, we must open a file (using the open function), the open function takes two arguments, the filename and a mode, which can be one of "w" (write) "r" (read) "a" (append).
For the "w" and "a" modes, if the file doesn't exist, it will be created, else if it exists, the "w" will overwrite the contents, and the "a" will append the data to the end of the existing contents.
So, we can open the file:
(setq open_file (open <filename> "w"))
And now open_file contains a file-descriptor for the open file that we can use in write-line.
example:
(write-line "Hello World" open_file)
When we are finished, we must close the file:
(close open_file)
Failure to close the file will render it read-only, and it cannot be deleted/modified until the file-descriptor has been wiped from the active document namespace.
Hope this helps!
Lee
Just a follow up example of what Lee said
(defun c:test (/ Input File0)
 ;Global variable to store the path
 (or *searchPath* (setq *searchPath* (getvar 'dwgprefix)))
 (if
   (and
    (setq File0
     (getfiled  "Select a file to export to"
        *searchPath*
        "txt"
        1
      (setq Input (getstring t "\nEnter text :"))
     ;Create a file stream
      (setq StreamWriter (open File0 "w"))
     (write-line Input StreamWriter)
     ;Close the stream to write the data to file
     (close StreamWriter)
Lol
That was easier then I thought
I however now seam to have trouble not so much in reading it but placing it where it currently says "DASIGNATURE20100218" of my lisp program.
What I do know is that I'm to read the text and set it as a variable and use that variable in the place where it currently says "DASIGNATURE20100218"
Do you know how to achieve this?
(P.s I know I should put this in a code box, but cant seem to find it on my page)
;;=== CODE STARTS HERE ===
(princ"Laden VAN alle nodigde bestanden, geduld A.U.B...")(princ)
(load "C:/Drawing Analyser/LSP/DAsign.lsp")
(load "C:/Drawing Analyser/LSP/DAflatten")
(load "C:/Drawing Analyser/LSP/DArename")
(load "C:/Drawing Analyser/LSP/DApurge")
(load "C:/Drawing Analyser/LSP/DAvariables")
(princ"Alle nodigde bestanden geladen...")(princ)
(princ"Analyseren van de tekening betrouwbaarheid, geduld A.U.B...")(princ)
(if (not (dictsearch (namedobjdict) "DASIGNATURE20100218"))
(command "vbaload" "C:/Drawing Analyser/DVB/DWG_ANALYSER.dvb")
(command "-vbarun" "Module1.DWG_ANALYSER")
) ;_ end of defun
;;=== CODE ENDS HERE ===
The mode arguments were case sensitive ( lower only ). Is that still the case? Maybe some things don't change after all -David
Perhaps look at my explanation again - and how it applies to the 'read' mode :)
Good point David,
ACAD Help:
The mode argument can be uppercase or lowercase. Note that in releases prior to AutoCAD 2000, mode had to be specified in lowercase.
So I always use lower to be on the safe side. :)
Okay I have looked and come up with the following, however it still dosnt work
(defun C: DAsign ()
(setq open_file (open "C:/Drawing Analyser/DIGITAL SIGNATURE./DIGITAL SIGNATURE.txt" "r"))
(setq DAsig (read-line f)
(princ"Bezig met de Digitale ondertekening van deze tekening als een vertrouwde *. dwg...")(princ)
(dictadd (namedobjdict) DAsig (entmakex '((0 . "DICTIONARY") (100 . "AcDbDictionary"))))
(princ"Tekenen is nu digitaal ondertekend, dank u voor uw geduld...")(princ)
) ;_ end of defun
Appears to be just a missing parenthesis and the read-line should actually using the open_file variable
(setq DAsig (read-line open_file)[b][color="Red"])[/color][/b]
Thanks, however it still reads syntax error when i run the lisp in AutoCAD?
Never mind i found the error. it was an extra fullstop (typo) in my file name.
Persistence pays off, glad you got it sorted
Regards
Jammie
