Wall R-value - where is it specified?
simply put - we have a new Revit project (our first) and we were looking at the wall properties to see if we could find the R-value, but no luck...
does anyone have some input on this?
many thanks!
:D
  • 4 weeks later...
1. Go to Settings/Project Parameters in the Pull Down Menu
2. Make sure you have access to Revit_Master_Shared_Parameters_v2.txt
3. Click the Add Button in the Project Parameters dialog box.
4. Select the Shared parameter option for Parameter Type and click Select/ Edit/ Browse.
5. Locate the file in Step 2 and select the R Value Param
5. Check the Wall Family in Catagories.
