QBall, I cannot see the code in the link that you posted - and the Autodesk page cannot be found. Are you able to post the code?
Yes, asos2000 had the right file. My link just references the original discussion where I first found that lisp.
to add some more info:
in 2007 when I typed "autolay" it would say
"VLR-Manager loaded. Loaded AutoLay[3.0].lsp"
type "autolay" again and it says "Unloaded AutoLay[3.0].lsp"
in 2010 when I type "autolay" it only says "Unloaded AutoLay[3.0].lsp". I have to use appload to load Autolay, but the lisp still doesn't actually work.
VLR-Manager.fas is loaded in 2010.
I don't know what else could be missing.
  • 1 month later...
  • 3 months later...
back to the top. Does anyone use this lisp? It was so handy. Maybe there's an alternative if I use design center or something?
